Patman
Staff member
Yep, moved from Oakville to Guelph about 5 weeks agoJust noticed you moved to Guelph, Patman.
My 2018 doesn't require the Dexos2 0w40 though, so I wouldn't have a problem getting the required 5w30 Dexos1 oil. But since the beginning I have always used the Dexos2 5w30 ESP Formula M1 and will continue doing so for a long time.For some reason I wouldn't trust them, and I wonder if most quick lube places would even stock Dexos2 oil.
Sounds like many folks would do 2x oci per year and you do 1, so at $30 equivalent that’s not terrible. Plus you’re using high quality oil and filters which is good. This last year has changed a lot of our driving habits so we all probably saved money on car maintenance, insurance, and gas. I usually do 2 ocis per year but only needed 1 last year. Probably going to be the same thing this year.Well I just swung by wally-world to get a filter and some oil for my yearly service on my 2UZ-FE 4runner.
5qt jug of M1 high mileage extended performance, plus 2 extra qts, and a Fram Ultraguard 3600. Almost $60 for everything. Anyone know what the going rate for this same oil change at a lube shop is running nowadays? $100+?
Went to U of G for my accounting undergrad, I enjoyed the town, people and environment there.
Also spent most of my summers in Oakville since my mom's side is from there. One uncle lives off Rebecca and Third Line, one lives off Upper Middle and Third Line and my aunt lives off Rebecca and Fourth Line. Great town, tons of "old" and new money there, expensive real estate and a good place to raise a family.
I hate they changed the name of Hopedale mall. . . Oh well. Why the move? Downsize? Family? Whatever the reason, hope you are enjoying the area now. Also, many more open roads to open the Vette up just a bit.
Right on. It’s not what happens to you in life but how you deal with it. Your attitude determines your altitude!I split up with my wife so all I could afford was a one bedroom condo in Guelph. But I've still got the Corvette and I have a great new girlfriend so life is goodShe lives in Milton, so I will be spending a lot of time in that area too
Smart guy. Kirkland oil. Don't understand the people who think they need to buy expensive, nationally marketed boutique oils like Royal Purple and Amsoil when the spec for them is no different than the spec for Kirkland Oil and Wally World oil.I can do an oil change in my Tundra for less than $28.
Kirkland oil and $5 Toyota OEM filter.
yes, it is $100 most places
That doesn't get you anything. The dry starts will cause more wear than leaving NEW oil in there.Will be doing some OCIs this month. At 6 months and only 500 miles or so, my Challenger probably doesn't necessarily need it based on time, and certainly not on miles, but I'm going to do one this month regardless. I just purchased 100 qts. of Chevron full synthetic for $1.50 / qt. on clearance so there's no reason to not do a change.
