So want to bring up an age old battle that I am sure occurs in most 2+ people households especially now that it is becoming winter again for us in the northern hemisphere. What do you have your heat....and for sake of argument cooling temp set to?
My condo is heat pump equipped as have been 100% of my previous apartments because I am in more temperate climates where heat pumps will suffice 99% of the time, there are those very rare low to mid teen days here in Atlanta where the super expensive electric heat strips need to kick on as the heat pump just can't cut it.
Anyhow I find 68 to be perfectly acceptable whereas my better half finds it "freezing" so it is a constant battle over temperature. Every time I find it getting warm and find the thermostat bumped up to 70 my argument that seems to work brilliantly is that my other half is more than welcome to manage and pay the electric bill, that usually works to have it set back to 68 for a week or so before the "I'm freezing" complaints start up again. Even with my Nest I don't schedule any setbacks while away as I understand heat pump systems will typically cost more to bring a place back to temp after 8-10 hours away versus just maintaining temp 24/7.
Luckily during the more expensive cooling season we both are good with 74 degrees while at home with a setback away temp of the system being off, fortunately I am ground floor with units on 3 sides (above and each adjoining wall) so the highest it has been in here while away for very extended periods of time was 79-80 which my system can get back to 74 within 1-1.5 hours.
So tell me do you have "preferred" temperatures and does it align with your other half preferred temp?
