As I turn the ignition, my pre-luber pump will run for 40 seconds automatically. I usually start the engine after 20 seconds of pumping. I have no problem starting the engine when the temp stays above 30sF. Last night the temp dropped to below 30F. This morning I followed the same routine, despite of 1 hour and 46 minutes of engine block heater/oil pan heater/ATF pan heater, and barely able to crank up the engine while the pump was running. The pump also grumbled for few seconds when it was turned on which never happened before. I assume this was due to cold thick oil in the pump. For those who have pre-lubers,
1) Do your pumps behave the same way?
2) Do you have hard time starting the engine due to battery drain by the pump in the winter?
3) If so, how do you get around this problem?
4) I am thinking of charging my battery (Odyssey PC1200) prior each engine startup, but, will the battery charging be effective under very cold temp?
5) Should I use a battery warmer? I am not sure if there is one for my Odyssey batter.
