Hi everyone,
I have a 1990 Ford F-150 4.9L
I know that pre-filling the filter is a good idea to reduce the amount of time the engine runs with no oil pressure on that first start up. I just changed the oil in my truck today (started the first Auto-RX rinse phase). I'm using Shell Rotella 15w-40 and I know that the thickness of the oil is contributing to the length of time with no oil pressure. That's why I want to pre-fill the filter next time to avoid this. Once I'm done with the Auto-RX, I'll probably starting using Rotella synth. 5w-40, which will aid with the dry start.
Anyway, here's my question...The filter mounts horizontally on the side of the block, not on an angle or anything, it just sticks straight out from the side of the block. Is there a way to pre-fill the filter that I won't have all my fresh oil spilling all over me and in my drain pan? The filter holds a quart of oil, and I don't want my nice expensive synthetic oil going to waste, but I also don't want a dry start either. Any suggestions?
