Originally Posted By: Donald
Originally Posted By: 440Magnum
Ouch. A BITOG favorite gets a ding.
Bad batch? Bottle filled with incorrect product?
Read the details, 10 samples of each.
Even if a bad batch, what does that say for their QA? You could be getting a bad batch also. (I use Amsoil so its not me who would be getting a bad batch of MaxLife).
I think its now pretty clear that the "advisory" is a bit bogus. This is a Dex VI spec fluid. The only problem is claiming full backward compatibility with Mercon and DexIII, and that's not even really Valvoline's fault. GM themselves (originators of the Dexron fluid in the first place!) seem to think that its OK to use thinner DexVI in DexIII applications. Fine for Hydramatics, but I'm not sure I'd use it in my Mopars, though. ATF+4 is more fully demonstrated as being DexIII compatible in those applications.
Other applications besides GM and Mopar? Hmmm.... I think we're just seeing Dexron become less and less universal as newer formulations come out. The DexVI spec is certainly less "combinable" with Mercon specs, as already pointed out.
