If you changed to a new brand/type of filter at the same time that you changed the oil I would tend to suspect the filter rather than the oil. Perhaps you got one with a weak anti-backflow valve.
As to whether PP in the new bottle is thinner than prior PP, I would highly suspect it is not, but to be sure you'd have to look at an old vs. new datasheet or a set of VOAs from the same lab. In any case, it is not obvious to me that slightly thinner old is going to pump up to the pressure required to turn of the light slower than slightly thicker oil. If anything the reverse might be true. I would expect a slightly thinner oil to pump to pressure a little quicker but the peak pressure would be slightly lower.
