OK, due to my ride I've been suffering the equivalent of Ren & Stimpy's "Space Madness" lately...at least for a few minutes or so. As you know, Dexron III superceded Dexron II some years back. The manual for my 2002 Mitsubishi-built Mopar requires "Dexron II" fluid for its 1.3 qt power steering unit. Pennzoil's data sheet on their Dexron III/Mercon fluid states "...can be used in passenger cars...and power steering systems which require Dexron, Dexron II, Dexron IIE, or Dexron III fluids."
http://www.pzlqs.com/Tech/Pdsheet/D...DexronIIIMerconAutomaticTransmissionFluid.pdf
But Chevron states about their comparable ATF, "Some recent Japanese and European made vehicles currently specify a Dexron-II product (for their transmissions). In these instances a Dexron-III product would NOT be suitable."
http://www.chevron.com/prodserv/nafl/auto/content/faq.shtm
So, Pennzoil says their D-III/Merc is OK for D-II power steering systems, but Chevron says their D-III/Merc is NOT OK for some D-II transmissions (and presumably power steering systems as well..?). Like I said, a bad case of Space Madness is setting in. What gives with the 2002 manual's Dexron II specification? I'm thinking -- or at least hoping -- that a rare topping off with D-III/Merc will not be of any significance in this ride, but still wonder what the rationale is behind stipulating the old spec'd fluid in the manual.
[ February 11, 2004, 10:18 PM: Message edited by: TC ]
