0) Consult OEM manual to see what, if any, special steps there might be.
1) Empty reservoir (could be combined with step 2)
2) Remove low pressure return line from reservoir and plug nipple securely,
3) Run/extend return hose from gear/rack into jug. Use a clear line so you can see color of oil.
4) Refill reservoir with new PS oil.
5) Have assistant start engine. Fluid will rapidly go down and you keep refilling until the return line oil is clear. Have the assistant run the steering once lock to lock during the process. You shouldn't have to run too much more than about 1.5 times the capacity of the system but if it's your first time, get plenty of extra. You'll feel like a one-armed paper hanger ( : < ).
6) Reconnect hose while losing as little from reservoir as possible. Top of reservoir and clean up any oil mess.
7) An option is to put a T-valve in the return line that allows you to just hook up and line to the empty nipple and direct oil to a jug.
8) Install an inline filter into the return line. There is no filter in a PS system at all. Magnefine makes one (same filter as for the trans but with different kit contents).
I installed a Magnefine into the return line of the rack and pinion steering in my F150 and ran it for 552 miles before resampling the oil. The ISO oil cleanliness code (google it) dropped from a dirty 20/17/12 to a clean 17/15/12. One code in any of the three number, e.g. 20 to 19, is a 50% drop in contamination. Similarly, when installed into the long-overdue-for-an-oil-change power steering of my ’86 F250 (recirculating ball system), it dropped the code from a filthy 21/18/14 to 18/16/13 in just 289 miles.
