Potential Issue With New Springs and Front Shocks on a Stock 2011 4Runner
Phoenix, AZ
Arrow in this image points to contact between the cut end of the lowest coil and the coil above it. I think this is a highly concentrated point of stress and there is a risk of it becoming a fatigue crack initiation site. What are your thoughts about it?
Where's the lower spring isolator? I think that would prevent contact, since it would move that first full coil up and away from the end.
Seen them crack a lot. Are you thinking of replacing them? Or just putting something there to relieve the stress?
At this moment, I want opinions from those with extensive suspension repair experience. I also want to hear from anyone with spring and/or suspension design experience. A Google search turned up one published technical paper analyzing fatigue failure due to contact between coils. See https://www.sciencedirect.com/science/article/pii/S2213290214000182
I would trust that Bilstein did their homework and wouldn't worry about it a bit.
I found a forum post where Bilstein denied a warranty claim because their 5100 shock was paired with a non-OEM spring. The lower coils of 4Runner OEM springs have wider pitch so as to not make contact.
That's not a Bilstein shock/spring combo?
Springs are cheap. I wouldn't give it another thought unless I had a reason to.
Dobinson C59-238 spring and Bilstein 5100 shock. Bilstein product description simply states, "... designed to work with OEM springs ..." My OEM springs had sagged 0.75 inches, so I elected to buy new springs.
At this moment, I want opinions from those with extensive suspension repair experience. I also want to hear from anyone with spring and/or suspension design experience. A Google search turned up one published technical paper analyzing a Mercedes spring fatigue failure due to contact between coils. See https://www.sciencedirect.com/science/article/pii/S2213290214000182
I have done loads of suspension work. I have rebuilt many Toyota suspensions before. I’m sure probably not as much as some others here though. They do crack a lot especially from the ones that were from up north I’ve pulled them off before and they have just been brittle. That is a cool study done by Mercedes and I’m glad they acknowledged it.
