Post your owners manual recommended OCI here
My 98 Corvette has an OLM in it, but it's owner's manual also has 10k or one year for the OCI. From 2001 and up, the Corvette's owner's manual now says 15k or one year.
Veh I: 04 Toyota Prius Hybrid -- 5k/6mos, all conditions, 5w-30 recommended (10w-30 permisible if no 5w-30 available).
Veh II: 01 Toyota Sequoia -- 5k/6mos severe service, 7.5k/12mos other-than-severe, 5w-30 recommended (10w-30 permisible if no 5w-30 available).
Veh III: 87 Cadillac Seville -- 3k/3mos severe service, 7.5k/12mos other-than-severe; 5w-30 (60*F and below), 10w-30 (0*F and above), SAE 30 (40*F and above), the cap just says 10w-30...
Toyota Kluger/Highlander V6 3.3 - 10k kms normal, 5k kms severe duty, doing Mobil 1 10W-30 at normal
Toyota Corolla - 10k kms normal, 5k kms severe, is new so doing several dino changes up to 10k then will use Mobil 1 10W-30 at normal
Roger
1990 Buick LaSabre 3800V6 (wintercar/beater:) ) 5W-30 "preferred"/10W-30 can be used above 0-degrees F. 3000 miles/3 months under severe conditions/towing. 7500 miles/6 months under normal conditions.
1996 Saturn SL2 1.9L DOHC
5W-30 "preferred"/10W-30 can be used if above 0-degrees F. 3000 miles/3 months under severe conditions. 6000 miles/6 months under normal conditions. (Do not use weights such as 10W-40 or 20W-50).
2001 Porsche 911 Turbo, oil every 15000 mi., filter every 30,000. 0w40 or 5w40 ACEA A3 syn.
94 Geo Metro.
Severe: Oil + filter at 3000 miles.
Normal: Oil at 7500 miles, filter every second oil change.
Use only 5W30, 10W30, or (if temps stay above freezing) straight 30.
04 Toyota Camry 4 cyl
5k mi/6 mos
04 Dodge Dakota V8
Severe: 3 mo/3k mi
Normal: 6 mo/6k mi
Volvo recommended OCI's for 1997 960
Extended periods of idling and/or low-speeds operation
Frequent short trips (less than 7 miles = 11 km)
Extended periods of driving in dusty and/or sandy areas
Trailer towing
Driving in mountainous areas
EVERY 6 MONTHS OR EVERY 5,000 miles= 8,000 km WHICHEVER COMES FIRST
Primarily highway driving
Frequent trips of longer than 7 miles = 11 km
EVERY 12 MONTHS OR EVERY 10,000 miles = 16,000 km WHICH EVER COMES FIRST
02 VW Jetta GLS 4 cylinder 2.0L
10,000 mile intervals
oil and filter change plus other maintenance listed on the page.
5W-40 preferred, meeting VW 500, 501 or 502, ACEA A2 or A3 and API SJ.
I don't remember exactly what is printed on the page about severe service.
Oil should be changed more if driven mostly heavy traffic, cold climates and dusty areas.
Don't have the owners manual for the Toyota Camry, sticker under hood.
92 Toyota Camry 4 cylinder 2.2L
7500 for normal service, 3750 for servere service.
10W-30 oil Above 0F(-18C), 5W-30 Below 50F(~10C)
Originally posted by buster:
2005 Honda Accord 2.4L
Oil
Severe service 5,000 miles
Normal service 10,000 miles
Oil Filter
Normal service 20,000 miles
Severe service 10,000 miles
SAme as Buster
My pre-2003 Toyota (corolla): 7500/6mo normal or 5000/4mo severe (this is the sludge friendly formula).
My post-2003 Toyota (RAV4): 5000/6mo (sludge fighting formula)
