Post your latest tractor oil change.
1989 Bolens/Iseki
Out- Shell Rotella T5 with Napa Gold 1064 filter.
In- Shell Rotella T5 10w30 with Napa Gold 1064 filter
The filter this time had a 'P' or o-ring type gasket and the crimp was somewhat different. Paint was different but the sticker was the same-ish. Made in India, previously made in Mexico.
2007 Kubota BX2350, 1372 hours
Out: Hastings Filter, Unknown oil
In: Supertech MP Filter, 2 Qts Rotella T4 15W40, 1 Qt JD 10W30 Break-in Fluid (leftover stock)
This will only be ran for a few hours then dumped. Recently reinstalled headgasket and a little bit of valve work on the cylinder head. Its not yet starting and belching black smoke. Continuing to troubleshoot.
2016 JD 1025R, 16 hours
Out: Factory Fill JD 10w30 break in oil, JD filter
In: Factory Fill JD 10w30 break in oil, Supertech 7317 filter
Planning to run until 100 hours
Also doing a UOA on the original fluid. It was sitting for 7 years, expecting it to be ugly.
Also doing a VOA on the JD 10w30 break in oil, I searched extensively and didnt see one.
2016 JD 1025R, 103 hours
Out: JD 10w30 break in oil, Supertech MP 7317 filter
In: Delo XSP 15w40, Fram Ultra 7317 filter
Transmission
Out: 12~ quarts factory Hygard, oem filter
In: 12~ quarts Hygard, oem filter
Front axle
Out: factory hygard
In: factory hygard
Front axle was definitely swirling with metal, consistent with other photos and videos. I use 4x4 most of the time. Transmission oil looked ok, I didn’t bother with the screen but will clean it next time. The transmission is noticeably quieter and less whiny after the change.
1017 hours on the 2022 JD 318G skid steer. Out was Co-op DMO SL 0w40 with JD filter. In was the same.
Manual calls for 500 hour oil changes. Its a 7.5L sump so not worth UOA.
John Deere 950 with 2180 hours on it.
104 hours, and about two years on this oil change.
Out: Blaine’s FF 5W40 with HPL 40EC and Fleetguard Filter
In: Rotella T6 0W40 and Fram Ultra OG wire backed XG3593A
23 Yanmar SA425; 26.3 hours.
Out: Factory fill 15W-40 and Yanmar OE filter.
In: Rotella T6 15W-40 and Yanmar D68XL65 (119305-35170) filter.
23 Yanmar SA425; 66.5 hours (completed 50 hour service).
  • Out: Rotella T6 15W-40 and Yanmar D68XL65 (119305-35170) filter.
  • In: Same, i.e. Rotella T6 15W-40 and Yanmar D68XL65 (119305-35170) filter.
  • Also replaced hydraulic fluid and two fluid filters with Yanmar OE filters. Hydraulic fluid used was Rotella HD Tractor Fluid @4.5 gallons.
  • Primary and secondary diesel filters and a filter o-ring also replaced with Yanmar OE parts.
  • Air filter check/possible replacement, and lubrication of pedals pending.
Oil and filter change on my 2014 Kioti CK30HST today. 2 years and 140 hours on the oil. Tractor currently has 670 hours on it.
Same oil/filter, out/in. AMSOIL Series 3000 5w30 HDD and WIX51381.
I decided to do a once over and when I retorqued the FEL bolts everyone of them turned. Several took almost a half turn at 110ft/lbs. Check your tractor FEL bolts !!
Out 3 quarts 15w40 Delo XSP, Out TG7317.
In 3 quarts 15w40 Supertech, In MP7317
25 hours on the oil, 580~ hours on the d722 engine, 1498 hours on the tractor, took a sample for 1st time analysis on this engine. Very little idle time and has been used for lots of landscape work and general tasks.
I guess this counts as a tractor. This is my parents 2005 Massey Ferguson ZT33 zero turn mower. It’s a 33 hp 3 cylinder diesel with a 60” deck. It’s a rebadged Iseki mower. I think the Iseki equivalent is an SZ330. It has an Iseki E3CD engine.
Out: Delo 400 SDE 15w40, Agco 72201828 oil filter. (Unknown interval)
In: Mobil Delvac 1300 Super 15w40 and a Fram XG4967.
The OEM filter number doesn’t cross to a Fram filter, but it crosses to a Wix 51360 or 51394. Those Wix filters cross to a Fram XG4967 or an XG2951. Both Wix filters have an 8-11 psi bypass valve. The Fram XG2951 has a 12 psi bypass valve and the XG4967 has a 14 psi bypass valve. The XG4967 was the closest in size to the OEM filter so I chose it. I think there may be room for the bigger XG2951 so I may try it next time.
View attachment 54543View attachment 54542
MF ZT33 (815.7 hours)
OCI: 213.5 hours (4/17/21 to 9/30/24)
Out:^
In: Rotella T4 15w40, XG4967
I also changed the coolant with Chevron Delo ELC. This is the second antifreeze change since it was new. I used my oil extractor to change the oil this time, I pulled the drain plug when it quit sucking oil out and not a single drop of oil came out of the drain hole.
2016 JD 1025R, 198 hours
Engine: out Delo XSP 15W40, TG7317 filter, in Supertech 15w40 conventional, Pentius PLXL6607
HST: out Hygard regular vis, OEM Filter, in Mobil Delvac UTF
Front Axle: out Hygard regular vis, in Mobil Delvac UTF
Engine oil, Front Axle, HST
cleaned out HST screen.
Transmission and hydraulics quieted down a bit. I'm probably done with buying Hygard and Kubota UDT.
Nice work. Are you cutting the Fram filter open? 😛😛
