Post Your Latest Power Steering Fluid Change
2020 Dodge Caravan, syringe and emptied and filled the reservoir until the quart of Mopar ATF+4 was empty, driving a few miles around the neighborhood between each fill.
The fluid that came out was NASTY and nowhere near the stock red color.
2009 Buick Lucerne
Replaced steering rack, flushed steering system
Out: not much unknown oil, about 3 quarts Fram Dex/Merc ATF
In: Fram Dex/Merc ATF
How is your Buick doing w ATF?
I just acquired an 07 Impala and used Lubegard PS fluid this time, little salty per qt at $15 when I can get a gal of ATF for $20. I am probably going to use Valvoline MV Import syn ATF as that is what I am using in my 93 C1500 and was trying to simplify my shelf.
Thanks
Thanks
This wasn't my car, it was something run through the shop I was working at. It did fine on the test drive with regular Dex/Merc. I have Mobil 1 ATF (Dex/Merc, synthetic) in my 04 Silverado and it does fine.
  • Like
Reactions: wlk
Great thanks for the update. I know older GMs don't care what you run in them. I just wasn't sure about if newer ones cared or not.
Thanks for the update.
