Post your latest oil change
2017 Toyota Camry 101,902 miles. 5,500-6,000 on oil. Got busy and went over a bit but it’s ok.
Out: 5 quarts Valvoline High Mileage Full Synthetic 0W-20
Off: Toyota YZZA1
In: 5 quarts Pennzoil Platinum High Mileage 0W-20 Full Synthetic
On: Fram PH9972
My dad chose the Pennzoil this time and then I found the filter on sale at Lowe’s for $4 so couldn’t beat that. This is the first time using Pennzoil in this car.
Farmer friend Colton’s 19’ Ran 2500 with Cummins diesel.
120k on it.
Out/off: Providence brand 10w-30 blend and Baldwin filter.
In/on: Providence brand synblend 10w-30 HDEO AND DONALDSON filter.
He did last oil change himself about 13k ago. I asked for used oil sample so I can UOA IT. STILL WAITING.
2024 rogue
Out NAPA Synthetic 0W20 - In Mobil 1 AFE 0W20. Running the filter another 5k
Update replaced the filter today @ 9383 mi.
2011 Toyota Tacoma Sr5 w/ 4.0 V6 I just bought. 127k miles.
Used car lot, they said they change the oil on everything before selling. Bought at 127k miles. Changed at 130k because that's what the sticker said. Maybe they changed the oil? Probably not. Had a valvoline oil filter on it that was insanely tight! Just moved to a different state and didn't have a claw type oil filter wrench ready. Filter o ring was also dry!
Drained hot, & used wheel ramps.
Kirkland 5w30 fully Synthetic
Toyota OEM oil filter
Project farm did testing, Kirkland oil was great. Same as Mobil 1 if I recall especially If you change it every 5000 miles/ lower interval. I do plan to change it every 5k miles. It's a PAO 3 oil if I remember correctly. Will have to check! View attachment 288083View attachment 288084
It’s stout oil 5,000 easy money for it
2005 Buick LaCrosse CXL
3800 Series III
Miles on Engine: 187094
Miles on Oil: 3999
Out: Quaker State 10w30 HM Full Synthetic
In: Quaker State 10w30 HM FS
Filter out: AC Delco PF47E
Filter In: AC Delco PF47E
OLM was at 66 percent but I am old-fashioned and change around 4k, plus we are expecting an extended heatwave soon. Engine specs 5w30 but i run 10w30 in summer, 5w30 in winter.
I had my oil changed on a 2005 Ford Taurus SE. I used to just drop it off at my old time mechanic and he'd use a WIX filter and Supertech High Mileage.
After reading the 100+ page VRP thread, I decided earlier to this to jump on that bandwagon. That plus with the $5 rebate, VRP is only around $25 for 5 quarts.
Out was my first cycle of VRP and my mechanic used WIX filter.
He set me at 4k intervals but said I can go over. I think the vibe her seems to be I could go 5k. I changed at 4200 and he said i could probably go a little longer next time.
In 5w30 VRP + STP Extended life S3600XL. I just got the AutoZone deal since some have recommended the oil filter there (I've never bought oil filters before) and with the filter, the oil was the same price as Walmart.
Taurus has about 136.5k miles. Probably will take back for another oil change around 141k.
This car either consumes or leaks about 1QT every oil change. It was at full around 3k miles into the interval. I topped off with a quart of VRP.
2015 Fiesta ST with a bigger turbo
Out: Schaeffer 9000 5w30
Msl51516
Short run on this, maybe 1200 miles. I know it’s not objective at all but the engine ran VERY noisy on this oil. And when I drained it, it was very very thin. Thinner than any other oil I’ve drained from this cars sump (or so it seemed). It didn’t smell like excessive fuel but something was going on here. Maybe I got a mislabeled batch I don’t know. I didn’t feel like using one of my analysis kits on it
In: Royal Purple HPS 5w30
Msl51516
'24 Toyota Land Cruiser
Pennzoil Platinum 5w-30 out and in
OE Toyota filter
The vehicle was sold with 2 years of "free" oil changes, but between getting an appointment, either shuffling back and forth from the Dealer or sitting in the mob scene waiting rooms of the local Dealers, I just did it myself and saved the receipts..... Very easy service. I may even be using better oil;)
OE Toyota filter
What made you not want to go with 0Wxx wt oil?
Good call on DIY oil change btw
2019 Toyota Camry Hybrid. 122,700 miles. OCI this time was approximately 6500 miles. I will be dialing it back to 5,000 mi OCIs, I need to rotate my tires more and might as well do it while doing an oil change.
Out: TGMO 0w16 and Toyota 90915-YZZN1
In: NAPA 0w16 and WIX 51394
I have two more WIX filters before I can start using my CQ Premiums and PG filters.
2017 Tacoma V6 (tuned, premium) 0W20 recommended
Out Amsoil Euro 0W-30, Amsoil Cartridge 7100 miles (longest OCI yet, no UOA but the oil looked so new, amazed even me)
In Amsoil SS 0W-40, Amsoil Cartridge
I will note my AM vapor can had the usual gassy oil (may 1/2 fluid ounce) and some white condensate for the first time. No worried.
Did this oil change on oil faithful about 2 weeks ago forgot to post it!
2010 Toyota Corolla 1.8L - 336 896KM at time of this change.
This is the third run of VR&P. While it was only around 5100KM and 6 months. 2000 of those kilometres was through the Canadian Rockies and back. Truly is a forever car.
Out VR&P 5W-30 and a Fram XG10358
In VR&P 5W-30 and a Champ P980XL
Also gave it a new air filter since it was cheap on prime day.
