Post your latest oil change
2017 Toyota Camry 101,902 miles. 5,500-6,000 on oil. Got busy and went over a bit but it’s ok.
Out: 5 quarts Valvoline High Mileage Full Synthetic 0W-20
Off: Toyota YZZA1
In: 5 quarts Pennzoil Platinum High Mileage 0W-20 Full Synthetic
On: Fram PH9972
My dad chose the Pennzoil this time and then I found the filter on sale at Lowe’s for $4 so couldn’t beat that. This is the first time using Pennzoil in this car.
2024 rogue
Out NAPA Synthetic 0W20 - In Mobil 1 AFE 0W20. Running the filter another 5k
Update replaced the filter today @ 9383 mi.
2011 Toyota Tacoma Sr5 w/ 4.0 V6 I just bought. 127k miles.
Used car lot, they said they change the oil on everything before selling. Bought at 127k miles. Changed at 130k because that's what the sticker said. Maybe they changed the oil? Probably not. Had a valvoline oil filter on it that was insanely tight! Just moved to a different state and didn't have a claw type oil filter wrench ready. Filter o ring was also dry!
Drained hot, & used wheel ramps.
Kirkland 5w30 fully Synthetic
Toyota OEM oil filter
Project farm did testing, Kirkland oil was great. Same as Mobil 1 if I recall especially If you change it every 5000 miles/ lower interval. I do plan to change it every 5k miles. It's a PAO 3 oil if I remember correctly. Will have to check! View attachment 288083View attachment 288084
It’s stout oil 5,000 easy money for it
