Post your latest oil change
2004 Mustang GT 146k miles
6,231 miles, 14 months
Out: 0W20 Pennzoil Platinum, Motorcraft FL820S
In: 6 qts 5W20 Supertech High Mileage Full Synthetic, Motorcraft FL820S, new drain plug o-ring.
Last time I was swayed to try 0W20 since the bottle sticker said same protection as 5W20, the engine ran and sounded no different. I felt better sticking with spec 5W20 this time.
Washed the Airaid non-oiled air filter, slipped the pre-filter back over it this time, since the filter gets much dirtier without it. Figure less dirt will make it into the engine and oil as well.
Not exactly an oil change, but...
Out: 1 quart Mobil 1 Extended Performance 5w30 roughly 5500 miles
In: 1 quart HPL Engine Cleaner 30
The Fram TG 7317 wasn't installed today. The plan is to let the EC30 start to do its thing and then change the filter. That could be tomorrow or as late as 3 November based upon my schedule. That later date would see roughly 250 miles before the filter change.
So what are your thoughts: good plan or bad plan?
In: 1 quart HPL Engine Cleaner30
I like that plan. I’m in same boat; have quart of HPL Engine Cleaner 30 in the 02’ Dakota. Oil already darkening and I have 200 miles since oil change.
In my case the oil was dark already so I ,ay or may not notice any change.
The extended plan is to run the EC30 for the next four weeks or 1000 miles before replacing with HPL Premium Plus 0w-30. This vehicle is parked outdoors and departs for work at 5:30 AM when it can be rather chilly over the winter.
2019 Honda HRV. 38,000 miles. Car belongs to family and was recently purchased.
What came out: unknown jobber oil, service champ oil filter.
What went in: Valvoline Restore and Protect 5W30 and Fram Fe7317
Also flushed coolant as well for reasons.
2014 Ford Transit Connect
1.6 Ecoboost 4 cylinder
Out: unknown oil, Motorcraft FL910S filter
In: Mobil 1 5w20, Motorcraft FL910S filter
2011 Mitsubishi Outlander Sport
2.0 4 cylinder
Out: unknown oil, Fram Extra Guard filter
In: STP Synthetic 0w20, STP Extended Life filter
