Post your latest oil change
2008 Chevy 1500 4.8
138,xxx miles
5 qts Super Tech syn 5W30, half quart Napa Syn 5W30, bottle of Rislone Hyperlube Engine Supplement
Fram PH10060 filter
2022 Honda Pilot
30,578 miles
5.7 quarts Napa syn 0W20
Napa Gold 7356 filter
I have used the Rislone Hy-per Lube Oil Supplement as well. Engine sounded smoother and a little less consumption. I believe they have discontinued this product though.
2010 Chevrolet HHR
2.2 Ecotec 4 cylinder
Out: unknown oil, unknown cartridge filter
In: Fram conventional 5w30, Swepco 502 Oil Improver, AcDelco PF457G filter
1974 Chevrolet C10
400 small block V8
Out: Valvoline VR1 20w50, WIX 51060 filter
In: Swepco 306 Supreme Formula 15w40, AcDelco PF1218 filter
2011 Chevrolet Impala
3.5 V6
Out: unknown oil, AcDelco PF61E filter
In: Fram conventional 10w30, Swepco 502 Oil Improver, AcDelco PF61E filter
1993 Volvo 240 wagon, 213,025 miles
Out: Motul 8100 5W40, MB 229.5 approval
In: same
Wix 51773 filter
The Ford 7 liter V8 filter has the same BVP as the Mann W917. It allows for a 5 liter fill instead of 4 quarts.
Is that the “red block” 2.3 the SVO guys would use parts from? If I recall correctly, the cylinder head from a 4cyl Volvo could be swapped onto a Ford 2.3 SVO engine to gain airflow. Been several years though so I could be confusing it with another.
Anyway, always liked those box Volvos.
Yes. It’s the boxy Volvo 240. Picture for your pleasure.
Doesn't the 1.5 turbo motor call for 0/20? Reason for 5w30 being used?
Yes, it does.
No reason, really.
I'm not a thin or thick leaning person, just have more 5w30 on hand than 0w20 since the Palisade is a 2022 and i accumulated a small stash since purchasing it. I'll be using both (20 and 30) in the Malibu, i believe.
2019 Kia Forte
2.0 4 cylinder
Out: unknown oil, Microgard MGL51334 filter
In: Fram synthetic 5w30, Swepco 502 Oil Improver, Napa Gold 1334 filter
Is that the Swepco 502 Moly version?
If it is, it's $32 for a 16oz bottle at Amazon.
That Xado stuff is the most expensive I found..... around $64 for 12 ounces.
