Post your latest oil change
2024 Prius Prime
10 000km on car
Realistically, maybe 4 or 5k tops on the oil..
I hope Dad has taught Daughter how to check oil level and, if needed, add oil with the quart that dad stashed in the trunk!
I tried it went nowhere it was a struggle just to teach her to open the hood 😆. But she's only little over 2 hours away I visit monthly so I check quick. So far I been lucky no car issues while she's at college I did put a full size tire no rim in the trunk. Car got low pressure warning was low added air next day low air again. Took to my friend owns a tire shop no leaks and been holding pressure 2 weeks. So threw the tire in the trunk just in case there's a issue.
2014 Ford Fusion
2.5L I4
~219000 miles on the clock
Changed it up this time and went with the Valvoline High Mileage 5W20 because the WM on my side of town was out of my normal Motorcraft oil. As usual, in went with the Motorcraft FL910S filter.
Changed my daughter's 2011 Kia Forte 2.0L I4.
~134500 miles
Also used the Valvoline High Mileage oil, which I've always used on her car, and used the Kia/Hyundai 26300-35504 filter.
2017 Hyundai Elantra daughter college car leaving next weekend a little over 2 hour ride from home about 90k miles on car. Out Valvoline white bottle 5/30 about 4k miles down 1/2 qt OE filter. In dad special blend of 2 qts of Mobil syn and 2 qts of Ace hardware Dino all 5/30 SP and OE filter.With the dad special blend I have 4 qts Mobil syn for the December oil change when she's on winter break the Mobil was a 6qt case from BJ's I caught on sale. Car takes 4.2 qts of oil topped off with Valvoline 5/30 white bottle leftover from last change
With the Hyundai motors I'm not planning on any Dino or syn blends.
I did buy 2 cases of the same Mobil FS when it was on sale on Amazon. I put that in future DIL's Tucson last change and Hyundai filter. I did the 5W-30 like you also.
The Kendall GT1 syn blend shop was using was seriously disgusting looking and smelling from the fuel dilution and really short trips.
My daughter is at SHU in CT. 2 hour ride on long island could be less than 30 miles away. It takes us anywhere from 1:30-4:00 hours from Centereach driving through Nassau and the bridges.
2019 Jeep Cherokee 2.4L, 105,227 mi, ~5,200 OCI
Out: PUP 0W-20, OE Mopar Filter, STP engine & cabin air filters
In: PUP 0W-20, OE Mopar Filter, STP engine & cabin air filters
Running strong, zero oil consumption.
Is that a funnel with the large cap?
Does the Cherokee have the lug bolts with the chrome caps? Serious PITA getting them off on FIL's '16 Renegade today. The caps swelled so impact socket (or factory lug wrench) wouldn't fit. https://bobistheoilguy.com/forums/threads/1-2-to-3-8-husky-impact-adaptor-broken.386496/#post-6990259
Yeah, it's a multi-vehicle oil funnel. You push the bottom of the funnel into the correct cap adaptor and it screws in.
No but they are VW-style lugnuts. Also a PITA.
M
I didn't take any pictures during it today. Rushed time frame.
Neighbors 2016 4Runner. 172k on motor, 12,200 miles on OCI.
Out- 6.6 qts 0W-20 Valvoline Restore and Protect. Fram XG10158 cartridge.
In- 5 qts of 5W-20 and 1.6 qts 0W-20 both Valvoline Restore and Protect. New factory YZZA5 cartridge filter.
Old Fram looking a bit odd.
My Eco tech 2.4 cartridge filter sometimes comes out like that.
Did an oil change and some rear suspension work on the old Passat last weekend. Just now getting around to posting. Also did an oil change on my brother’s Corolla. He never rest his oil life indicator and ran his last oil a bit long….
2010 Passat 2.0T DSG
Oil change mileage - 218,325
Oil change date - 8/17/24
Motor oil used - 5L LiquiMoly Molygen 5w40
Oil Filter Used - VW Genuine
Miles on oil - 6368
Oil out - LiquiMoly Leichtlauf 5w40 w/ Ceratec
Mileage for next oil change - 225,825
2018 Corolla SE 1.8L
Oil change mileage - 215,432
Oil change date - 8/18/24
Motor oil used - Mobil 1 0w-20 ep
Oil Filter Used - Mobil M103A
Miles on oil - 13,113
Oil & Filter out - Mobil 1 0w-20 EP & Wix filter
