Post your latest oil change
2018 Ford F-250
6.2 V8
Out: Schaeffer's 9000 5w30, Motorcraft FL820S filter
In: Schaeffer's 9000 5w30, Motorcraft FL820S filter
1989 GMC Sierra 2500
5.7 TBI V8
Out: Swepco 306 Supreme Formula 15w40, AcDelco PF1218 filter
In: Swepco 306 Supreme Formula 15w40, AcDelco PF1218 filter
2011 Ford F-150
3.5 Ecoboost V6
Out: Schaeffer's 9000 5w30, Motorcraft FL500S filter
In: Schaeffer's 9000 5w30, Motorcraft FL500S filter
2012 Chevrolet Silverado 1500
5.3 Vortec V8
Out: unknown oil, Fram Extra Guard PH10060 filter
In: Fram Synthetic 5w30, AcDelco PF48E filter
2020 Ford Ecosport at work.
18,xxx miles on odometer
Out: Iffy Lube oil and PZ-21 made in China filter. Filter on so tight had to use my ancient craftsman claw to remove it.
In: safety Kleen 5w30 blend and Auto Extra 618-51348 filter
Hated to do it.
4200 miles on Kirkland full synthetic 5w20 and FL500s
Didn’t want to rotate the 20s myself.
1967 Ford Fairlane 500
390 Ford V8
Out: Schaeffer's Micron Moly SAE 30 Racing Oil, Motorcraft FL1A filter
In: Swepco 306 Supreme Formula 10w30, Motorcraft FL1A filter
2001 Chevrolet Silverado 1500
4.3 Vortec V6
Out: Royal Purple HPS 10w30, AcDelco PF52E filter
In: Schaeffer's 7000 10w30, AcDelco PF52E filter
Doing 2 here.
1) 2018 VW Atlas. 44,500 miles/4,200 mile OCI. Needed to change it before my wife took a long road trip or would have run it to 5K.
Out: 6L Liquimoly Leichtlauf High Tech 5W40, Mahle filter/o-ring/drain plug.
In: 6L Liquimoly Leichtlauf High Tech 5W40, Mahle filter/o-ring/drain plug. Should be good for a 5K OCI. Also always run a can of Liquimoly DI Jectron every oil change through the gas tank.
2) 2003 VW Passat W8 wagon. 115,000 miles/3,900 mile OCI. ~2K since adding HPL Engine Cleaner so time to dump it.
Out: 5.5L Liquimoly Leichtlauf High Tech 5W40, 0.5 qt Quaker State Euro 5W40, 2 qt HPL Engine Cleaner, 2x cans Liquimoly MoS2, 2x cans Liquimoly Engine Flush (that's a mouthfull!), Hangst filter/o-ring/drain plug.
In: 9L Liquimoly Leichtlauf High Tech 5W40, Hangst filter/o-ring/drain plug. Should be good for a 5K OCI. Also always run a can of Liquimoly Jectron every oil change through the gas tank.
All oil change supplies will go back to FCP Euro for store credit using their Lifetime Replacement Guarantee with the wipers from W8 and a bottle of Motul RBF600 brake fluid makes it about a $225 credit which will cover the next services on my Sportwagen (DSG, Haldex). Love FCP! Return shipping using Pirate Ship should be around $20.
2021 Tacoma 2.7L/4x4 / 2TR-FE
Out: Toyota dealer house oil
In: Kirkland 5w30
Miles: 22,650
I noticed the engine was a little smoother/quieter with whatever the dealer used (esp. at higher RPM after the VVT-i switchover) compared to the Mobil 1 Extended Performance 0w20 I had used previously so I decided to see if 5w30 had the same effect. This engine is currently spec'd with 0W-20 but originally called for 5w30 when it first came out about 20 years ago. I'm curious if I'll notice a slight MPG loss.
Also did our other car at the same time
2012 Toyota Yaris 1.5 1NZ-FE
Out: Mobil 1 Extended Performance 0w20
In: Kirkland 5w30
Miles: 56,980
One other note: first time using it... this Warren oil smells a lot more pungent than M1
In: Kirkland 5w30
Miles: 22,650
In: Kirkland 5w30
Miles: 56,980
One other note: first time using it... this Warren oil smells a lot more pungent than M1View attachment 134479
I noticed that too with the 0W-20.
You put a new drain plug in with every oil change? Why?
