Post your latest oil change
Daughter's 2012 Mazda 3 Skyactiv-GS. She's home for the holidays so I decided to get the oil change done earlier than later. Currently has 174xxx km. Six month OCI and around 8000 km driven. No extra oil needed inbetween. Oil looked good. Weather was half decent for Canadian December to do the change in the garage at -5C.
Out: 0W20 PP synthetic Fram TG6607
xXjPLFzOk68CduiEacCDjoJ_ZclKnjgwEyp3JIfS-XyqIlOG2sxjKn_dmIc4sW_22zkZBvl-YS3SJlAHMe_8VYz2_88sFtMV3_VDsBm7Y4nYYxAzedFt6r6WGpYVp8eYPoOHQ4nL0S9s0LdcY-zM8jzigfli8VS_YkQ6cfZkrtnMwU8defnjYN_EHmpEztSn7FhWD8OUSig5wjao-vD_bpHBnddUA5D_UVLJ_Fxthuwe48Hmf2fXzy1OcAbdqSNjC9eDooiUtydHKKs5oeOZ61-46Lku13b-g00NXjn6XnBQveork0jmwJKaBg49j3lhsKm8zzqWBq__Vyjz9cVmmGuZkjv7lzbTy4EWaJCsKOtRqzBt1Q9UcRsycIwWIXuEyfnOP-XiTvTj7WyMzPk1ZQ1cE51v-UqdthbqUETIDZ9-Tkjo--jOVV0fEkUxRJN7A5Y0yNAeX4YrrmJ49SZqZGHqhYCeqoLtzWp6u5-Nlwx5u379K2notSeKAxUS6pvDMefkSSwqf288iT_oNSgmDGLf2FMU2wuvpGJyCTLFk0WDQswABMXYWJz2iJZUN3YngPGEgZmZKl139ogYyf1hDtUFxowepYB0OY3Uh9Ez2xjot9EsskueAUhzh1Wm9vkOG2dxlgEB1E9qttriIYIRa-oO1qeBUWedzVqdn7PvQKuAPlEqLUzRNJ-Pus1LepuhH0SjfZJ2KYEgQwqbTgfT6hqnc8deqEEcCqOUXtWO_945-ZX_aO87trDZrhCXj-5rL8rWjks_JLUkfqtbIKCCdjqFLAQZPVr8uYEao1DIFoSSs607wdxuQL0RET43j9LvxVBCtv_Fo6mShOWPbdecZVhSj_vpT34MWB6SCF74DUo-233CMyxYwYYoS0SrtU6cQ3l9EZPPKvmyEkU-pPuoQpGzJsqt0QCKHMFRaMaCjUUVkA=w391-h695-no
In: 0W20 OEM synthetic (picked for $12 on clearance) Fram TG6607
HVHUKdH5DTa1Tt4bU33ShSEFqXNVnjmdbD5Lw8upRNIt0yoQx2l_5Re3O1ifq9QpmNshwfDWP2m2URp_MZtPfttuWxscqsdez7qSDodGD-quXs81Jl8yA8iWck9XxLbD5Q7GB3xWowAiEKU2Ag4xepqUN7gRCltkVRHIyDjZfO71v0ODYJlsNOMTFH4cP67EU6dB2BLm-79PznEfSH2_GIz4T8nsq-XOZzebqjwCNymWld8kQWoe2Hpz9aiETlJFwnl7nyUoNbwZ6TgZFHQ8LN7we7jVwbWcqo-g_mR1Pu12Wweau2s-Q0p6wdY4LFq2FsjIuq1uEvXXX3O3LM4IEcbfwpmzgPTvBR3kNgd2PmHARA7tIsChouwSshg-klJQsstzvvsbZ7mNoJhejhrANfjbLk-A5RKbZ13PxexOY-yVl5lzKyFAAwsRjAxfvhGmBwEDE79anSczJGE34Gv8rreP3v7ZtEvtgRWD68CYtBol4OQk0bOrdBnNthVH2hbsnhuw6bqZxHt02mYPitjAtIcEw1mAdh7jDPwjWZlFKWCyBCeEz4XyKb0VIjIK628kisTitmvU0VGdOlUUNYqoiv44GVAKyPqqhM8_BrRZpcDtV9PkFUQUhbTXgViiwjR133iyjg0JYwXDKUKlccGCbDRHPP9P2y-I_OuRn7k_wili6IgU9uJChIAXchJ6h5OvxfQyAxEPCpeSsPhoFsGuPtUuUG8cFfdgbaLywZ1uajWoiyborrlN6SLSZZo9DVPQ-mK8Syk85Lvfy8Nwy0xrm8_YXLoXQPHpHxanQNANGmAuBxsik5aSM9nbLTnWCwf6ZN3hqixiAUiSf9UlYoX7IsCjkWekNByENmcnlUlrophmmYzIvqIotClrO7scoPNntY_kSL0lBDMFqKtvqImE0IAfJ51CaOqGvLOWsioSeLQfqA=w391-h695-no
2014 Subaru Forester 6MT 2.5L NA
ODO: 117,361
Consumed: ~0.5 qt
Top up: 0 qt
Miles on oil: 117,361 - 114,353 = 3,008
Estimated hours on OCI: 3,008/30 = 100.3
Out: 5.0 quarts mix (3 qts NAPA 20w-50 + 3 qts NAPA SAE 40 + 2.5 qts QS Euro 5w-40 + 1 qt ETO2197 + 0.5 qt Biotech)
In: 4.0 quarts blend (3 qts Delvac 1300 + 1 qt M1EPHM) + 1.5 quarts blend (3 qts NAPA 20w-50 + 3 qts NAPA SAE 40 + 3 qts QS Euro 5w-40 + 1 qt ETO2197)
Off: XG7317
Estimated hours on filter: 100.3
Miles on filter: 3,008
On: XG7317
I moved and changed jobs right prior to doing this OCI; My commute averages 30mph instead of 40mph now, and has been reduced to 40mins one-way. This is the lowest consumption rate I have experienced yet. Started to drive harder, and consumption picked up to something noticeable, and so I went back to my previous driving style to run out the CI. The oil level remained at the top of the dipstick up until around 2,400 miles into the OCI when I did such test. Oil came out darker than I thought it would.
ODO: 121,000
Consumed: ~0.8 qt
Top up: 0.5 qt
Miles on oil: 121,000 - 117,361 = 3,639
Estimated hours on OCI: 3,639/30 = 121.3
Out: 4.0 quarts blend (3 qts Delvac 1300 + 1 qt M1EPHM) + 1.5 quarts blend (3 qts NAPA 20w-50 + 3 qts NAPA SAE 40 + 3 qts QS Euro 5w-40 + 1 qt ETO2197)
In: 5.0 qts Frankenbrew of consolidated leftovers from many jugs/blends
Off: N/A; XG7317 round 2
Estimated hours on filter: 121.3
Miles on filter: 3,639
On: N/A; XG7317 round 2
Got a cut in the inner boot of a CV axle I just put on back in April. :rolleyes:
Replaced the CV axle, then did the oil change.
Also discovered where some noise is coming from--passenger rear wheel bearing sounds to be going out.
Catch can is still catching a good bit of oil still.
2019 Kia Soul, Gamma 1.6L GDI
Approx 30,400 on car, 3,300 on oil
Out: 3 quarts of PP 5w30, 1 qt QS “All mileage” 10w40, Kia filter
In: 4 quarts PP 5w30, Kia filter
One bottle of Techron Complete was added to the tank a week before oil change. Tire pressure set to 35 psi.
Sooty exhaust
Supposed to use toilet paper to wipe eh.
2021 Nissan Titan Platinum Reserve
10,303 miles on truck
Out 6.9 qts Mobil 1 0w20 SUV and Truck with Nissan 15208-9E01A OEM Filter
*3500 miles on oil and filter
In 3 qts Mobil 1 0w20 Extended Performance + 3 qts Quaker State 0w20 High Mileage Full Synth + 1 qt 5w30 Shield Choice Synthetic Blend with Nissan 15208-9E01A OEM filter
*Will run for another 3500 to 4k miles for next change. I was trying to use up some left over oil from other changes. Manual calls 6.9 qts but 7 puts oil level right under full mark on dipstick. Added bottle Techron to tank and set tire PSI to 40psi.
(Edited for miles on oil @ 3500 miles)
