I don't know if they still make them but if you're going to put a timing belt in there I would try to see if you can get one from GReddy. They're a tad bit more expensive but they're designed for a hardware and tear. Even if you weren't going to Hot rod it they're such a pain in the butt to do that it may be worth it to have a little bit of extra wiggle room and reliability. Thanks for posting I'd like to see further what you get done what it looks likeFirst oil change for my newly acquired 1999 Honda Civic LX. I bought it for $2,600. I’ve spent the last couple of months updating the maintenance and fixing things that were not working.
So far I’ve completed
—a full tuneup (distributor cap, rotor, spark plug wires and spark plugs
—Replaced rear lower control arms, camber arms and hardware
—Replaced struts with coilovers
—Bought new tires/wheels
—Replaced the radio and speakers
—Replaced front headlight buckets and bulbs
—Replaced rear tail lamps
—Replaced front pipe and cat
—I’m slowly working through several transmission drain and fills with Redline D4.
I still have to replace the front brake rotors and pads and do a timing belt service. Car is running great and I am having fun driving and working on it.
On to the oil change—221,574 miles
Out: Valvoline conventional 5w30 and Valvoline oil filter. (Info per Carfax, work was done at a Valvoline Instant Oil Change)
In: Pennzoil Platinum 5w-30 and an Altrom Ultra 8 oil filter.
According to some here who state that Mobil 1 EP oils have improved their base stock / additives in the GF-6 SP D1 / Gen 3 oils to be some of the best easily available synthetic oils you can buy for a great price $26 @ WM) . The Fram Ultra #9688 is what I use with my Hyundai 2.4L GDI engine and has never been an issue and works great ... Great choice in oil and oil filter for your Tucson !Tucson 15,000 miles on the od , doing 5k intervals.
Out : Castrol Edge EP 5w30 / fram ultra 9688
In : Mobil 1 EP 5w30 / fram ultra 9688 (oil from walmart $26.47)
What happened to the super tech you were going to use22 Accent
After a 4400 mile New Years round trip to see my Sis in Phoenix. Yes, in the Accent. I went alone since wifey had to work. It performed flawlessly and averaged 42 mpg total.
Since i joined BITOG..... constant indecision. LolWhat happened to the super tech you were going to use![]()
But this... this will be used from now on.![]()
Thanks ! I'm a Castrol Edge and Castrol Edge EP fan but , not opposed to using Valvoline synthetic or Mobil 1. I just grabbed what was available that day the wally world.According to some here who state that Mobil 1 EP oils have improved their base stock / additives in the GF-6 SP D1 / Gen 3 oils to be some of the best easily available synthetic oils you can buy for a great price $26 @ WM) . The Fram Ultra #9688 is what I use with my Hyundai 2.4L GDI engine and has never been an issue and works great ... Great choice in oil and oil filter for your Tucson !
22 Accent
Not at all. LOLSwipe the pipe ?![]()
