Post your latest oil change
2013 Silverado 1500 5.3L, 67,200 miles.
5,200 miles and 5 months on oil. OLM at 34%. No oil consumed or added.
8,700 miles and 11 months on filter.
Out: Mobil 1 0w-30 AFE, OG Fram Ultra XG10060.
In: Mobil 1 0w-30 AFE, Amsoil EaO17.
2013 Silverado 1500 5.3L, 62,000 miles.
3,500 miles and 6 months on oil. OLM at 30%. No oil consumed or added.
Mobil 1 0w-30 AFE out and in and left the OG Fram Ultra XG10060 on for a second OCI.
Also extracted 12oz of power steering fluid and refilled with OE fluid.
My old 2004 Subaru Forester (son’s car)
@ 163500 miles
Out SuperTech synthetic 5W30 HM
and Fram TG 6607
In went 3 quarts Mobil 1 5W40 Euro and 1 quart Mobil 1 5W30 with another Fram TG6607.
Just changed the plugs, wires, and ignition coil pack too. Ready for the race track! Not
1966 Chevrolet Malibu
283 small block V8
Out: unknown oil, Champ AC PF35 reproduction filter
In: Castrol GTX Classic 20w50, Champ AC PF35 reproduction filter
Note: this car has a Mr. Gasket spin on filter adapter, otherwise it would take a cartridge filter
66 was a nice car... The 64 thru 67 are my favorite A bodies. I believe Chevrolet changed the cannister filter in 68.
I use that Castrol oil in my classics as well.
'18 Hyundai Accent SE w/ 6 speed auto . Plan to leave in until late April to mid May of '23 . Figure better oil , filter for longevity . 🤞
OUT : Shell Rotella Gas Truck 5w-30 ( SN+,GF-5 ) w/ FRAM Extra Guard PH9688 ( Miles On Oil : 2,164 , Time In : 7/3/22 > 9/30/22 )
IN : PENNZOIL Ultra Platinum 5w-20 ( SP,GF-6A ) with FRAM Titanium FS9688
This car isn't mine. I'm out of the classic car game. I still work on a few though. I went through the brakes on this Malibu about five years ago, someone else has replaced the fuel system about two years ago. It's been in the same family since new, and sees about 2500 miles a year. The GTX Classic is a good match to this application.
Drum brakes all around? I did the brakes on our '65 4-4-2 with some "special" shoes that were supposed to offer better bite and ability to shed heat better. I would love to convert the fronts to discs but then the car would be less original. And the 14" steel wheels would not fit.
2013 Lincoln MKZ 139851 miles 3.7L Ti-VCT V6.
Out: Unknow other than 1QT top off of 0W-40 Rotella, typical shop oil filter (maybe a mighty). Filter was very light and drained quickly. Also poured a QT of clean 0W-40 through it while drain plug was out.
In: Shell Rotella Gas Truck 5W-20 SN+, 1QT of HPL SAE30 Engine Cleaner, Purolator TL22500 filter
2017 Ford Explorer XLT 3.5 NA with 61,563 miles. This was a 6 month 6,700 mile oci. Also did second transmission drain and refill. Got 4.5 quarts this time…
out - 6qts Castrol Edge 5w-20 and ST filter
in - 6qts Castrol Magnatec 5w-20 and Mobil 1 extended drain filter
2014 Chevrolet Trax 1.4L Turbo, 122,431 km
Out: Valvoline Advanced Full Synthetic 5w30, AC Delco PF2257G oil filter, 50% olm, 6295 km OCI
In: 4L Mobil 1 AFE 0w30, Hengst E611H-D442 oil filter
2016 Hyundai Santa Fe 2.0L Turbo GDI, 44,440 km
Out: Pennzoil Ultra Platinum 5w30, Mann W811/80 oil filter, 5286 km OCI
In: 4.8L Pennzoil Platinum 5w30, Mann W811/80 oil filter
2011 Mazda 6, 8,000 mile OCI
Out: Valvoline Syn 5w-30, Fram Tough Guard
In: Valvoline Syn 5w-30, Fram Tough Guard
2018 Buick Encore, 5,000 mile OCI
Out: Valvoline Syn 5w-30, STP oil filter
In: Valvoline Syn 5w-30, AC Delco oil filter
2021 Explorer 2.3L TGDI. 13,834 miles. OCI 5,295.
Out - Dealer bulk
In - SuperTech 5w30 full syn
Vehicle has a lifetime power train warranty, so I let the dealer change the oil when OLM goes off (approx 10,000 miles). Dilution is a problem with this vehicle, very strong gas smell in the oil. I change it at 5,000 but don’t reset OLM. When OLM goes off, dealer has record of a change at OLM interval for warranty purposes. I have averaged 25.5 MPG, so I don’t think there is anything wrong with the injectors, just the nature of TGDI engines.
Left FL-910S filter on. If Ford thinks 10,000 interval is ok, then filter should be fine.
2020 Ford EcoSport 2.0L 6AT AWD 9103 miles odo, oci ~3k interval.
QSFS 5W20 and Motorcraft FL-910S spin on.
I had to purchase the filter at the dealer since there have been none in stock at my local Walmart for months.
AZ wanted 10 bucks. Sadly the Ford dealer wanted $8.20 which is also high.
I am Reverting to the 20 grade and a 5W as I am anticpating a brutal winter.
Reminds me I have to order a oil sample kit from Blackstone. I got a sample of the 10W30 I ran from Spring up to now.
I am doing 2x OCI per year now, Spring and Fall regardless of mileage.
- Ken
