Post your latest oil change
2004 Honda S2000, 56350 miles, 3000 OCI
Out: Pennzoil Ultra Platinum 10W-30, Wix XP 51334XP Filter
In: Pennzoil Ultra Platinum 10W-30, Genuine Honda OEM Filter.
Changed it early to go back to 3750mi OCI, last OCI was at maintenance schedule time limit of 6 months. They say that because of the VTEC system, the oil pump is more than capable to lubricate a V12 engine, so the larger OEM filter compared to aftermarket won't restrict the pump.
5 oil changes today, the whole family minus dad's truck (still at 78% iOLM)
2014 Acura RDX 114,xxx miles - Mom's
OUT: Not sure, likely PPHM 0W-20, M1 filter. 6500mi oci
IN: 4.5qt Supertech full syn 5w-30, Napa Platinum filter
2013 Hyundai Elantra GT 6MT - 125,xxx miles - Wife's
OUT: M1 0w-20 AFE, M1 filter. 7k mi oci
IN: 4.2qt Supertech Syn 5W-30, Napa Platinum filter
2017 VW Golf 1.8t 102,xxx miles - Mine
OUT: M1 Euro 0w-40, Mann filter. 6k mi oci
IN: 5.8qt Castrol Euro 0w-40, Mann filter
2006 Audi A3 189,885 miles - Also mine
OUT: PP Euro 0w-40, K&N filter. ~8500mi oci. Needs about a qt every 2.5k so it's had top-ups.
IN: 4qt M1 0w-40, 1qt PP 0W-40, Fram Ultra filter
2001 Jeep Cherokee 60th ed. 204,xxx miles - Also mine
OUT: Valvoline Maxlife 5w-30, 5qt blend 1qt full syn. Supertech ST16 filter. 2500mi oci (>1 year, decided to go ahead and change it while mucked up)
IN:6qt Supertech 5w-30 full syn, Napa Platinum filter
Other recent maint. -
Golf Air & Cabin air filters
Elantra got a new NGK coil, replaced m/t fluid, and installed KYB gas-a-just monotube shocks in the rear
Car takes 4.5 quarts. Changed oil to 3.5 quarts 0w20 supertech FS HM and 1 quart of 5w30 redline. Fram ultra filter.
Anyone know what my final viscosity likely is?
2008 F150 - 206,063 miles
Out: Liqui Moly Special Tec AA 5W-30, LM Ceratec, Motorcraft FL-820S
In: Liqui Moly Special Tec AA 5W-20, LM MOS2, Motorcraft FL-820S
Friend's 2013 Toyota Highlander LE, 4 cylinder
118,800 miles
OCI: 4,800 miles, 7 months
Out: Coastal Fast Lube bulk 5w-20 conventional, jobber cartridge filter
In: Napa synthetic 0w-20, Fram CH9972 filter
My 2013 Camry 4-cyl with 112K.
6,600 mi OCI this time.
Out -- 0W-20 synthetic, but which brand u can't recall.
In -- 4.6 qts of 5W20 Shell RGT 5W-20 and OEM cartridge filter
1974 EMD SD40-2; 5 drums (250 US gallons) Mobil SAE 40 & 7 2 foot long cartridge filters.
2018 Chev 3500 6.6L duramax; 15W40 Delo 400 and Hastings filter.
6 weeks and 1,000 miles later, my daughter took the truck to the dealer for an air bag recall and they did a free oil change.
Thought I was drunk when I read EMD SD40. A locomotive OCI ?? . Man you win :ROFLMAO: :ROFLMAO: :ROFLMAO:
Dave
The back story was a cracked cylinder liner and head leaked about a hundred gallons of water into the oil.
It was luck that a UOA caught the problem in time. Marine & locomotive oils separate water and don't mix well.
Quite often if an engine has been sitting for a few days, I can drain a couple 5 gallon pails of water from the
sump drain pipe.
Just a guess, but probably just a slightly thicker 0/20. I dont think theres enough 5/30 there to significantly change the overall viscosity.
Moved the civic coupe to Castrol Edge Extended Performance 5w 20 with fram ultra and the Audi A4 to Castrol Edge 0w 40 with factory cartridge filter. Seems the Ravenol RUP 5w 40 is no longer available from Blauparts anymore.
2005 Chevy Silverado 2500HD Crew Cab - 6.0L V8 , LQ4
Miles on vehicle : 151,401
OCI : 4472 miles , 1 year 3 months , OLM @ 25%
Out : 6 qts of QSUD 10W-30 , PF61E
In : 6 qts (Smart Change box) of Havoline Conventional 5W-30 and Pronto PO4006 jobber oil filter.
2005 Ford Explorer V6 with just over 178,000 miles. My sister is driving it for now. Took it to her local Jiffy Lube for an oil change. Also changed air filter. Cost her $113.00! o_O I told her that's why I never use them. Too spendy, plus, you need to double-check that caps are closed and there's no leaks.
OUT: SuperTech HM 5W-30 and Fram filter
IN: Pennzoil Gold 5W-30 and Unknown Jiffy Lube filter
You gotta be kidding! I could see if it was at least a name brand synthetic and premium oil filter. Obviously the air filter markup is outrageous.
