Post your latest oil change
2016 Toyota Avalon 3.5L
51,250 miles
out - no idea, first oil change with the car
in - 6.4 quarts 0w20 Valvoline Modern Engine and Toyota filter
2019 Subaru Impreza Sport.
6129 miles on car. Miles on oil. 1,653
6 Months oil change due to warranty.
Out/In Whatever the Subaru dealer used which I am assuming is their own brand of oil and filter.
1964 Buick Riviera 425 nailhead
Out: Unknown
In: CarQuest 10w30, STP S25
1964 Buick Skylark GS 350
Out: Unknown, CarQuest 85042
In: CarQuest 10w30, CarQuest 85042
1978 Chevrolet Corvette 350
Out: Unknown, Promotive PH5313
In: Harvest King 10W-40, CarQuest 84099
2019 Passat 2.0T
Yes, I know, not vw508.00. I'm perfectly fine with that.
Friend's 2011 Chevy Impala 152k
Out : 3 qts unknown oil and AC Delco filter
In: 3.5 qts Supertech Conventional HM 5w30 + Fram TG
Kinda surprised a 3.5 V6 has such a small sump.
2018 Nissan Frontier
Out: Supertech synthetic 5W30 and Mobil 1 Filter
In: Supertech conventional 5w30 and FVP Reliaguard filter.
Using up my leftover stash of oil and filters from my dearly departed 1999 Frontier. (departed due to transmission, not engine problems). The off-brand filters have the same base stamp (champion labs?) as the Mobil 1 with a rubber anti drainback valve instead of silicone. Should be more than fine for the next 5k miles.
2020 F-150 2.7 ecoboost
1351 miles
Drained: factory fill
Factory filter
Filled: Shell Rotella gas truck 5w30
motorcaft FL2062A
Wanted to do an oil change before my vacation. Plan is roughly 2500 miles just on vacation.
Side note here's a comparison between the factory FL2062 and the FL2062A which superseded it. Kind of interesting difference
2014 Toyota Prado 3.0L Turbo Diesel
I normally blend my own as I am fortunate enough to work in the lubricants industry.
However, the last 2 changes have been special, To prove shelf life of oil is a fallacy my last 2 oil changes have been with an oil 11 years older than the engine it has gone into - found in distributor's warehouse, batch dated 13 May 2003. Tested it before putting it in and did a used oil analysis after last service. No issues and none were expected in any case.
Jeff.
2016 Volvo XC90 with 76,5XX miles. As posted elsewhere, it started to consume oil a few K miles ago. I added a can of BG EPR, ran it for 20 minutes at 1200 RPM, the changed the oil and filter.
In went Mobil 1 5W30 High Mileage and a Wix filter. Hopefully the oil consumption improves.
2004 Mitsubishi Galant 2.4L (180,927 overall miles)
Out -- 2 quarts of Mobil 1 V-Twin 20W50, 1 bottle of Rislone High Mileage Engine Treatment, 2 quarts of 5W30 ST conventional
In -- 4.2 quarts of Castrol Edge High Mileage 5W30 & 2nd run on Fram Ultra
Installed a Fumoto Drain Valve he purchased.
1997 Honda Civic HX, 226,176 miles.
Out: Castrol Extended 5w30 & Fram XG3593a
In service just shy of 3,000 miles. Dumped early to change the PCV valve (it's right above the oil filter).
In: Shell Rotella T6 5w-40 & Fram PH3593a
Went thicker to see if it would help with the oil leak I have (yes I am actively changing seals, ect to fix them).
