2011 Hyundai Genesis 4.6 L V-8. 13,911 miles. Pennzoil Platinum 5w-20, Hyundai filter
2020 Ram 1500 5.7 eTorque, 1266 miles
Out: Factory Fill
In: PP 5W-20 SN+, Mopar Oil Filter
Oil Changes suck on these trucks. The oil drains onto the sway bar. The oil filter is positioned above the steering rack.
Out: Factory Fill
2020 Honda Pilot LX 2WD
Mileage on vehicle - 4,992
OCI - 6 months and 4,992 miles - OLM @ 15%
Out - Factory Fill and OEM oil filter
In - 6 qts of dealer bulk 0W-20 and OEM oil filter -
Honda of Tomball service dept performed the oil change (gasp !)
Lease vehicle and oil changes were included in the initial purchase.
My first direct injection engine and I'm still on the fence if I like it or not... Time will tell.
I'm inquiring with the service dept to see what brand of bulk oil they use.
Geez.. what breed of dinosaur came out of the drain plug??Changed oil and filter in 49 Farmall C. Been 20 years.
I’ve had good luck at the local Ford Quick Lane for oil changes. Only 25 bucks for 5w30 syn blend. Air filters at WM are abt 11 bucks for future reference.2005 Ford Explorer V6 with just over 178,000 miles. My sister is driving it for now. Took it to her local Jiffy Lube for an oil change. Also changed air filter. Cost her $113.00!I told her that's why I never use them. Too spendy, plus, you need to double-check that caps are closed and there's no leaks.
OUT: SuperTech HM 5W-30 and Fram filter
IN: Pennzoil Gold 5W-30 and Unknown Jiffy Lube filter
Out: Factory Fill
