Post your latest oil change
2018 Chevrolet Silverado Crew Cab Z71 5.3
34300 miles 7.1K OCI.
Out 8 quarts AC Delco 0W20 Semi-Synthetic AC Delco E-Core filter.
In 8 quarts PPHM 0W20 and WIX Filter.
The Grey Goose... Nissan Altima VQ two door coupe
Out: Peak high mileage 5w30+ Wix 57356
In: Carquest high mileage full synthetic 5w30 + Wix XP 57356
Now at 263,000 miles...
Bought car with 39,990 miles.
1997 Ford explorer 5.0
Off defense filter 4 quarts of formulashell 5w30 and 1 quart of Rotella 15w40
Heres whai put in and on
Is that one of those pickup Explorers with a now 22 year-old plastic bed cover that bleeds rust-color?
Curious how the metal underneath has fared. My guess is that it remains rock-solid underneath, maybe some topical brown that's not pitted.
Thats my 98 f250 ld. Its mainly just dirty in the box. I need to spray it out once it warms up. The herculiner is ok. I should have put an extra coating on
2019 Hyundai Santa Fe 2.4 GDI (holds 5qt 3oz)
OUT
Factory-fill Q.S. conv 5W20 and OEM Mann-Hummel oil filter @ 2909 miles
IN
Castrol Edge Black 5W30 and NAPA 21334 Pro Select Mann-Hummel oil filter
1999 Dodge Ram Sport 1500 w/52K miles. Approx 7K on the OCI.
Out - Kendall Semi Syn 10w-30 and Carquest Red Filter
In - Napa Syn 10w-30 and Napa Platinum Filter (current $22 special)
2000 Acura RL w/159,200 miles after A HEAD GASKET REPLACEMENT 2,000 miles before.
I just got the car and it clicked a lot (by my estimation) so I tried Formula Shell 5W-30.
It had quieted several engines before so in it went.
It did indeed quiet it down noticeably.
I had tried Mobil1 0W-40 European Formula which didn't effect the noise one bit.
2007 Toyota Yaris, 146,087 km
out: 3.7L castrol edge 5w30, bosch workshop oil filter, 7776 km oci
in: 3.7L valvoline maxlife syn blend 5w30, bosch workshop oil filter
Just accidentally bought a 1947 Co-Op E3 Tractor and a manure spreader Sunday... and drove it home 12 miles! Great time! Changed whatever the gross stuff was in the engine with Castrol 20w-50 twice while the oil filter is on its way from eBay, and will then run on a Napa Gold 1006 and Delo 5w-40.
Changed the trans/rearend, PTO gearbox and belt pulley gearbox.
Out- water mostly, and some slime.
In- Regal R&O ISO 100 hydraulic oil.
I got 20 gallons of new sealed hydraulic oil from work. They were going to dump it in the waste oil tank.
When the filter gets here I'll dump and fill everything again with the Delo and 10 gallons of Super Tech HD tractor fluid, also bought on clearance!
