Post your latest oil change
2018 Ford F-150 4x4 STX with 2.7 ecoboost.
8100 miles, out goes the factory fill.
In goes 6 qts of Quaker state 5w30 synthetic with some filter. I didn't watch that closely it's my assigned fleet truck.
Was in Odessa to take care of some business and while around civilization got a po and went to Midas for an oil change. I was there for 20-30 m8 utes at most.
Also got a new air filter, due to dust loading.
The computer was going to take it past 10k despite a lot of rough slow dusty roads. And 315 hours of engine run time.
That's an average of 25 mph for the interval, no sample taken. Old Oil was black new oil was golden.
I usually run Texaco gas in it and it does pretty good in the Thunderdome.
I would imagine you are on the oilfield? Fleet trucks are usually having a tough life driving them on the county roads lol
I have worked production Health and Safety in the North Slope of Alaska, Colorado, New Mexico and now west Texas.
My previous fleet truck was a 2007 with the 4.6, it lasted me a while,I only replaced tires , 1 set of shocks and struts and it had hail damage but was running well when I turned it in where it was eventually auctioned. It's how you drive those rough roads. No reason to hurry I am not a firefighter.
2003 Camry with 110K and a 5K OCI.
Out: Valvoline Synpower 5W30 and Fram TG
In: Mobil Super 5W30 and Fram TG
Used approximately 1/2 quart for the OCI. Starting to smoke a little on start up.
2008 Chevy Trailblazer 4.2 106k miles
Smittys Syn Blend 5W30, Napa Proselect 21522
drain plug 19 ft lbs
2008 Accord 2.4 135k miles
PP HM 10W30, Napa Platinum 47356
drain plug 29 ft lbs
2008 Altima 2.4 174k miles
Napa Syn HM 10W30 (Valvoline) Full brand OEM equivalent filter
drain plug 25 ft lbs
Good lord I haven't seen oil that cheap around here since Smitty's was at Kmart. Ironically, our tsc is in part of the old Kmart building. I should go check it out to see if my stores doing that sale.
2018 Silverado 3500
[Linked Image]
Originally Posted by CleverUserName
Why are you mixing Biosyn HD with Archoil? Didn't we already tell you not to do that?
I don't listen to real well. What was your reason for NOT dosing RLI with 9100?
Originally Posted by MuzzleFlash40
2016 Santa Fe Sport - 70,150 mi
Out - Pennzoil Platinum 5w30 & OE - 5,100 mi OCI
In - Castrol Syntec 5w30 & OE
Boatload of Calcium and hardly any Magnesium in that Syntec. You might see that 2.4 GDI Santa Fe on Life Support....lol
Keep a tank of oxygen in your back seat.....lol pt2
2010 Jeep Wrangler 3.8
120k on vehicle
3 months (unknown mileage) on oil
Out - Milesyn blend 10w30, Bosch Workshop oil filter
In - Supertech conventional 5w30, ST filter
2010 Corolla Base 1.8
143k on vehicle
5117 miles on oil
Out - Milesyn Blend 5w20, Toyota OEM
In - Amazon Basics 5w20 synthetic, Toyota OEM
2011 Toyota Prius, 186,880 miles
Out: Supertech Dexos Full Syn 0w-20, Toyota Filter, about 1K
In: Idemitsu Zepro Advanced Moly 0w-20, Toyota Filter.
The car is 19 years old. That makes it old enough to drink (in Canada, at least... which is close enough to home). No well drinks here. We're celebrating with top shelf all the way!
[Linked Image]
Out: Mobil 1 5W30, AC Delco PF46
In: Redline 5W30, AC Delco PF46
Out: Bowling Green's reddest ATF
In: Redline D4 ATF
Out: Kentucky crude (smelling) 75W90
In: Redline 75W90
Out: Pure Saginaw power steering fluid
In: Redline Power Steering Fluid
While I haven't owned it for but a year, I'm pretty sure this is the first change of the trans, diff, and power steering @ ~44,000 miles. The oil was changed last year, maybe 1,250 miles ago.
2013 F150 5.0 @ 109781 miles
Out: Castrol Edge 5W-30 / Fram Ultra 10575
OCI was 12935 miles over 11 months
In: Castrol Edge 5W-30 (SN Plus) / Purolator Boss PBL 22500
Advance Auto special (yeah laugh at me for using the Boss... what can I say?)
I cut open the used Ultra and it looked like a new filter dipped in dirty oil. No defects that I could see. I made a last minute run to Advance and bought two oil/filter combos of their Castrol/Boss monthly special. My Coyote survived a previous run of 9500 miles using a Boss so I'm not going to fret about it, even though I wish it was more efficient.
