Do good on that oil? It made my wifes traverse seem smoother and a difference in valvetrain noise coming from PUP, asking because I have a 19 2.7 f1502018 Ford F-150 with 2.7 Ecoboost
In: Mobil 1 Truck and SUV 5W30 and Motorcraft FL2062
Out: same
Seems fine but I’m not one to notice different sounds with different oils. The oil level doesn’t move at all between six-month oil changes.Do good on that oil? It made my wifes traverse seem smoother and a difference in valvetrain noise coming from PUP, asking because I have a 19 2.7 f150
I'm fairly sure that 76 5w30 WAS a synthetic blend, now discontinued and replaced by the Phillips 66 brand. I used the Conoco Phillips oils (Conoco, 76 and Kendall) for several years with no problems. It was and still is good stuff, even the blends.2005 Ford Explorer w/184,138 miles
OUT: Union 76 5w30 Conventional Oil & unknown filter
IN: Same
My sister takes it to a local tire and repair place that uses 76 lubricants.
2016 Nissan Altima w/88,318 miles
OUT: Pennzoil Platinum 5w30 Synthetic & Magnetti Morelli filter
IN: Same
Oil change done at dealership as part of car purchase.
Thanks for the info. I live several hours from my sister, who is using my Explorer. She updates me when she has the oil changed. Wasn't sure if 76 was conventional or synthetic, so, I just guessed. The repair shop just states using "76 lubricants". They do have great oils, though. Used several flavors in past vehicles.I'm fairly sure that 76 5w30 WAS a synthetic blend, now discontinued and replaced by the Phillips 66 brand. I used the Conoco Phillips oils (Conoco, 76 and Kendall) for several years with no problems. It was and still is good stuff, even the blends.
Most supply their own oil and filter. I just change it.Wow, Red Crow, for as many cars as you change the oil in, I would expect you to be pumping from a bulk barrel most of the time. You must have a lot of family and friends.![]()
You need a used oil furnace in your shop.Most supply their own oil and filter. I just change it.
I have 5 5 gallon buckets I pour used oil in. I take it to the local auto zone for recycling. They let me go in the back and dump it myself. I dress warm and also have a propane lamp heater that works decent. I finish my work then go warm up in the apartment.You need a used oil furnace in your shop.
