Why though?
Why though?
Hahaha! Nope. I am currently running the car up and down the highway right now. I'll put 4k on this oil and go back to 0-40 on the next change.
I don't think I'd do that, MB specs that 40 grade because they require an HTHS viscosity above 3.5, and in an AMG tuned twin turbo engine, I think I'd stick with MB recommendation, failing that maybe a full synthetic 5w40 or 15w40 HDEO, not a a resource conserving ILSAC 5w30 oil.Hahaha! Nope. Had 15 qts laying around. I am currently running the car up and down the highway right now. I'll put 4k on this oil and go back to 0-40 on the next change.
Ok I'm gonna say it. Putting anything in car with AMG on the engine cover but what the owners manual states is just plain stupid. I imagine you have enough money to pay for the repairs, I'm sure you're not worried about it.
To burn through excess oil I had. I am currently running the vehicle up and down a highway at 2k rpm at a light load. I am not worried about it. I will have changed the oil by the time I plan on any type of heat or load bearing activity with any meaning.Dare I ask the reason for significantly deviating from the minimum HTHS requirement for this engine?
I am not worried about it.Ok I'm gonna say it. Putting anything in car with AMG on the engine cover but what the owners manual states is just plain stupid. I imagine you have enough money to pay for the repairs, I'm sure you're not worried about it.
I can see why a 40wt would be recommenced but I am not convinced running 30wt is detrimental to the engine under light load on the highway.Couldn't you just have flipped it on Craigslist or something?
Seems unnecessarily risky to run something with insufficient HTHS in this application, but it's your car.
I can see why a 40wt would be recommenced but I am not convinced running 30wt is detrimental to the engine under light load on the highway.![]()
@SugarMouthI can see why a 40wt would be recommenced but I am not convinced running 30wt is detrimental to the engine under light load on the highway.![]()
I have not found the HTHS for Warren 5-30, is it documented anywhere?It's not the grade on the bottle, there are plenty of xW-30's that meet the HTHS requirements for your engine, this just isn't one of them. Energy Conserving xW-30's are all typically HTHS of ~3.0cP, whilst Euro-spec A3/B4 xW-30's and xW-40's are all >=3.5cP for HTHS. Where this becomes important is bearings, which produce high temp/high shear conditions, which is what HTHS represents.
I have no problems with that. Where would you prefer I get the service from Backstone or? I'll likely drop it around 4k-4.5k miles so it will not have many miles on it.@SugarMouth
I agree with your logic, and I think you will be fine. But I couldn’t do it myself, I would still run an A3/B4 40 grade since it is easy enough to get, and save up the ILSAC 30 grade for something else.
But I’m happy that you are game enough to give it a go. Hey, would you do a UOA for us? That will get the full value out of this oil change (for the community) and settle a lot of debate. But it’s up to you, I hesitate to ask another to spend money on my curiosity.
I doff my hat to you.
You are a gentleman !I have no problems with that. Where would you prefer I get the service from Backstone or? I'll likely drop it around 4k-4.5k miles so it will not have many miles on it.
If it's not A3/B4, the HTHS will be ~3.0cP.
It could be 3.0 or 3.1 or 3.2 or even 3.3 or 3.4....
I know Havoline high mileage 5w30 has been reported at 3.4.
Mobil Super synthetic 5w30 was reported at 3.3.
I believe Kendall full synthetic 5w30 TDS was at 3.2. Has was Valvoline 5w30 full synthetic at 3.2.
Having said all of that....
Regular Warren Oil 5w30 is likely 3.0 to 3.1.
