Post your latest oil change
2006 Ford Taurus SES 3.0L 12v "Vulcan" V6
77,070 Miles
Out:
QSUD 0W-20 Synthetic
Motorcraft Oil Filter
In:
Quaker State Defy 5W-20 HM Syn Blend
Purolator "PureOne" L__195 Filter
1999 Mercury Sable LS 3.0L 24v Duratec V6
95+K Miles
Out:
(Mostly) Quaker State 5W-30
Motorcraft FL820 Filter
In:
Formula Shell (Clean Engine) 5W-30
Motorcraft Filter
1998 Mercury Mystique LS 2.5L 24v "Baby Duratec" V6
135,526 Miles
Out: QSUD 5W-30
Fram Tough Guard (gray) Filter
In:
Valvoline MaxLife 5W-30 Blend (5 qts. +1 qt. of 5W-30 NextGen ML)
Purolator Pureone Filter
2011 Mazda 3 - 15038 miles:
Out: Eneos 5w30/K&N HP-1002
In: M1 5w20/K&N HP-1002
2012 Ford Fiesta 5112 miles:
Out: Red Line 5w20/K&N HP-1002
In: Red Line 0w20/K&N HP-1002
--Matt
2000 VW Beetle
88,431 miles
5200 on oil
Out-Pennzoil Platinum and PureOne filter
In- Castrol Edge with Syntec 5w30 and Bosch Distance Plus filter for 6 months
1981 Toyota Corolla - 148,000km
Out: Petro Canada Bulk 10w30 - 10,000km on OCI - Napa Proselect 1394
Oil change place had used non-specced filter, much smaller than standard, but the numbers looked OK so I imagine it was safe.
Had to break out the 1/2 inch drive socket set to get the drain plug out and the filter required hard pulling with a chain type filter wrench.
In: Valvoline 10w30 Conventional - Napa Proselect 1068
Even put a new drain plug gasket for good measure.
1998 BMW 328is (M52) @ 113,583 miles
Out: BMW 5w-30 Full Synthetic and OEM Mann filter 7476 miles/10 months on oil. Still had 1 green bar left on the OLM. I took a sample for a Blackstone UOA.
In: 6.7qts of BMW 5w-30 Full synthetic and another OEM Mann filter.
Yesterday
1998 MS s500 @56,380 miles
Out: Unknown oil/ Filtron(Not sure) Filter, approximately 4200 miles on oil and unknown time period. Took a sample for UOA.
Little electric oil extractor (from Amazon) and jumper battery (since car battery is located in the trunk) worked great.
Had to jack up engine in order to fully remove oil filter cap and filter itself. I guess engine mounts on my "to do" list now.
In: 8 liters (8.5q) of Lubro Moly TopTec 4100 5w-40 and Mahle filter.
Than accidentally hit half full jug and spilled about 1-2 liters of finest oil ...
bad and very hot day...
Yesterday, 7/1/12
2011 Honda Pilot
5781 miles (15% oil life)
Out: Factory fill and factory Honeywell filter
In: 4.5 qts Mobil 1 5w-20 and Mobil 1 110 filter.
All for $33 even.
Forgot to order a new drain gasket so I turned the old one over. No leaks the next day. I also rotated the tires and learned that I need taller jack stands. Guess I'll have to buy some new ones, what a shame
2010 Honda Civic sedan. 22,000kms on the odo. 50% on the Honda MM.
Out: dealer bulk 5W20 and oem A02 filer
In: 50% (2 litres) Motomaster Formula 1 Full Synth 5W20 and 50% Quaker State Advanced Durability 5W20 with a free Fram PH7317 filter.
Coming out:
Oil: Castrol GTX with some valvoline oil
Filter: Purolator Classic
Coming in:
Oil: Castrol GTX
Filter: Purolator Pure One
Mileage 297,XXX
'06 Mazda6s 3.0L
Miles on car: 62,500
Miles on oil: 5,500
Time on oil: 8 months
Out: QSUD 5W-20, MC FL-820s
In: Citgo Syn-blend 5W-20, Purolator Classic L24651
08 Santa Fe, V6, 38000 Mi,
Garaged, will out-live me
M1 Syn 5W20 @ 4000
All OEM filters
2000 Elantra, 2.0, 215000 Mi
Garaged, no leaks, no smoke, no sludge
Castrol HM 10W30 @ 3000
Uses miniscule oil amt
All OEM filters
2005 Toyota Sienna. Mileage: 90,000
Mobil 1 5-30 High Mileage; Filter: Toyota OEM
2010 Mazda3 2.0 Mileage 35,000
Mazda Idemitsu 0W-20; Filter: Mazda OEM
1998 Ford Contour 2.5 V6 Mileage 89,000
Valvoline Maxlife 5W-30; Filter: K&N
1994 Ford F-150 5.0 Mileage 120,000
Mobil 1 5W-30 High Mileage; Filter: Motorcraft
1991 Chevy K5 Full Size Blazer. Mileage: 109,000
Castrol GTX 10W40; ACDelco filter
2007 Ford Focus. Mileage: 39,000
Motorcraft 5W20 Synthetic Blend; Motocraft filter
Something a bit different.
Briggs and Stratton 650 series engine 190 cc displacement. Troy Built 21 inch rear bag lawn mower.
Out: PYB 10W30
In: PYB 10W30
A bit over one pint of oil used. Engine uses very little oil.
Last changed April 15, 2011 and changed July 4, 2012. I admit being a bit late as I like to change before the first mowing of the new springtime.
Removed blade for sharpening soon within a few days. Air filter looks fine and does not need changing.
2011 Honda CRV 18,561 miles
Mobil 1 0-20w
Using the honda mileage minder so this worked out to 10,000 from the last change.
