2006 Harley road king Police bike.
Out : whatever the last owner used.
I decided to try something different than what I usually use. And used 4 qts of Castrol 20/50 full synthetic oil that stated it was for use in Harleys.
The oil filter was a new Harley filter I've had since I wrecked my other Road king.,,
Miles on Oil: 18,004 - 15,558 = 2,4462014 Triumph Tiger 800XC
Miles on Oil: 15,558 - 13,570 = 1,988
Hours on oil: ~50
Out: 3qt Delvac 1300 15w-40 + 1qt Mobil1 V-twin 20w50
In: 1 gal of pre-blend (3.5 qts Mobil 1 15w-50 + 1 qt QS Euro + 1.875 qts Napa SAE 40 + 0.625 qt ASTO 500)
Qts Consumed: 0 qts
Off: Triumph OEM filter (given from PO)
Hours on Filter: ~50
On: MP6607
Nice shifting throughout the life of this blend (it did diminish in quality, still though.) Its very hard to tell the color-condition of the sump oil on this bike through the sight glass. Color seemed pretty dark, so I changed it--It had been a while since the last change.
I still feel a premature oil change was a good idea...not being sure how much it had been test ridden (short jaunts & not getting up to operating temp), when the prior oil change was actually done, etc;Good deal on getting the S40 with low miles! Are you saying you changed the oil because you clunked some shifts? I would not let that influence doing an oil change moving forward, not an issue. Less than 600 miles on the oil isn't even letting the oil break in, ha ha.
