Post your latest HDEO change
2004 Dodge Grand Caravan 3.3L V6
In: Liqui Moly Pro Line Engine Flush
Out: Mobil Delvac 1 ESP 5w-40 + flush and K&N HP-2004 filter
In: 2 qts Rotella T6 5w-40 + 3qts T6 15w-40 + 10oz Motorkote and Carquest 85515HD Filter.
EDIT: -10oz of oil for the Motorkote that replaced it.
LT150 with a 15hp Koehler. I dumped ST FS 10w30 and filled with Blain’s F&F 5w40 synthetic HDEO.
I was having trouble getting the mower started in the colder weather to blow snow. It’s better now with the 5w40. The bonus is this oil should work for both winter and summer.
Just my $0.02
Just my $0.02
That should do great year around? What part of Iowa are you from? I’m currently staying in the Quad Cities area for the night. Blains is always a stop for my when I get up this way.
You are in my neck of the woods for sure! We live in the QC's. Blain's is right up there with Menard's for me!
just my $0.02
2017 Ram 3500. 123,000km on truck, 25,000km on oil.
Out was Co-op DMO 10w30 conventional.
In was Co-op DMO 5w30 semi synthetic.
I could not find any Baldwin or Hastings oil filters locally so I ran a Napa gold. Seeing as I used approx. 3000 litres of fuel this index, I only changed the rear fuel filter. I will do the front every other time. I used the Baldwin version.
2007 Chevy Silverado 2500HD LBZ Duramax
Out: Schaeffer 711 (15w40)
IN: Schaeffer 9012 (10w30)
New Filter: Amsoil EA052
86 f350 6.9 IDI
Out- Traveller 15w40, FL1995A
IN- Castrol GTX Diesel 15w40 and 5 ounces of Redline engine break in additive (zddp), FL1995A
3K intervals
90 W250 5.9 12V
Out-Valvoline Premium Blue 15w40. Fleetguard LF9028
In - Mobil Delvac 15w40 Extreme, Donaldson DBL7349
5k intervals
2016 Ram 3500 DRW Cummins... Providence 5w40 Synthetic from Rural King ($32 for 2 gallon jug) and a $1.30 factory wholesaler closeout Champion Brand Filter from Rock Auto. Pretty sure in had Delvac 1300 in it previous time. Never know what will be next but it will be the cheapest s#!+ on the shelf that meets the specs
2012 Ram 2500 6.7 Cummins with 149,829 miles.
10,080 miles / 318 hours on this change.
Out: 5w40 VPBE & Fleetguard LF16035
In: 5w40 VPBE & Fleetguard LF9028
I’ll cut & post the Fleetguard LF16035 that came off this weekend when I have time.
15w-40 T5 in my fresh rebuilt 17Hp Kawasaki (1991 John Deere 260 Garden Tractor) as of this mow I've put 5 hours on it.
15w-40 T6 2007 F-350 that I'm going to run for 7500 and send oil sample. Will change back to 5k intervals though.
