Post your latest HDEO change
2012 Ram 2500 6.7L with 160,037 miles on it.
10,208 miles / 311 hours on this change.
Out: 5w40 Valvoline Premium Blue Extreme & Fleetguard LF9028
In: Two quarts HP SAE 40EC, Three quarts Rotella T6 5w40, Three quarts Delo 400LE 15w40, Four quarts Rotella T6 15w40 & Donaldson P558615
That's a real Frankenbrew lol... Just using up oil or is this like the Colonel's secret recipe? I have a 2012 2550 as well, so asking for a friend. :ROFLMAO:
Just my $0.02
Just my $0.02
Just using up open jugs of oil I had on hand. It’s all 40 weight and this will probably be a 5k run with the High Performance Lubricants Engine Cleaner. I probably have 11 more unopened gallons of 5w40 on the shelf.
I didn't want to start a whole new thread on this..... But if Diesel and European formulated oils are better, and so much more, "heavy duty", why not use them for everything? Diesels have high compression that places greater loads on connecting rod and crankshaft bearings. And the Europeans are famous for driving 300 MPH on the Autobahn for days on end.
So why are we screwing around with all of these "normal" oils for our puddle jumpers?
I use nothing but various 15w40's in my whole Japanese fleet. I am a BIG proponent of HDEO's in gas burners. Check out any of my Blackstone used oil analysis I have posted. Delvac 1300 12500 to 15,000 miles OCI's and good to go. No issues with the variable valve timing systems and my Mazda/Ford duratec engines burn lots less HDEO's than they do the the 5W-20 swill the manual recommends.
2017 Peterbilt 389 Glider Kit, c15 ACERT MXS
-Mystik JT-8 15w50 10 gallons, CAT oil filter
How do you like the Mystik JT8? Any reason for 15w50? I’ve got 12 gallons of 15w40 cued up for future changes on my Cummins Ram.
BTW nice looking rig!
Just my $0.02
Just my $0.02
I like it a lot, I like the 15w50 because I get a better OCI with it, my CAT lets me know when the oil is finished because I will start getting a little more blow by, it takes longer with the 50 than the 40. If that makes sense.
Bobcat S130 w/Kubota diesel at 4,752 hours. 207 hrs and one year on this OCI.
Out: John Deere Plus 50 II 15w40 and a Bobcat filter.
In: Mobil Delvac Synthetic 15w40 and Bobcat filter.
Also changed the fuel filter.
The 6.7 Cummins is the most un-fussy engine on the planet when it comes to oil. IMO, you're good to go for another 300 hours.
Did the little 318G skid steer again today. Previous oil change was at the 285 hour mark to get out the break in and then today was to get her back on track at 505 hours.
Out was the mix of 10w30 and 0w40 and an Asian JD filter. In went Co-op DMO group 4 0w40 and the same JD filter. I couldn't find a compatible Napa gold or Baldwin/Hastings oil filter locally so I settled for the same old.
