post your latest differential fluid change
2006 Mercedes R320 CDI W251 4matic 230.000 km:
Front diff: Out probably original fill. Black. In Ravenol VSG 75W-90 16,8 cSt@100C oil GL5. Speced for 75W-85 GL5.
Rear diff: Out probably original fill. Dark brown. In Ravenol VSG 75W-90 GL5. Speced for 75W-85 GL5.
Transfer case: Out probably original fill. Red/black. In Fuchs Titan ATF 3353 236.12. Speced for 236.12 ATF.
2016 Ford Expedition. I changed out the factory fill on the rear diff. a few years ago when it had 50k miles. Put in Delo Gear EP-5 80W-90 with 1 bottle of Motorcraft friction modifier and all was well until a few weeks ago. Now at 100k miles, the LSD started chattering horribly when turning, it was like hitting rumble strips. Did not do it on short trips, but on 20+ mile trips it was bad, especially with a heavy load in the vehicle.
Last weekend I drained the oil and looked it over in the pan and did not see anything unusual. The drain & fill plug magnets did not have anything scary on them either. Refilled with Royal Purple 75w-90 and 1 bottle of Motorcraft friction modifier, and did a bunch of figure 8's in a local parking lot. We have been on a few 50+ trips with it and all is well.
1984 Oldsmobile Cutlass Supreme
Axle seal replacement, pulled cover to access c clips
Out: unknown oil
In: Shell Spirax 80w90
Replaced 900ml of Amsoil Severe Gear 75W-110 with Severe Gear 75W-90. Now close to a 50/50 blend.
2013 Ford Escape 2.0L 93,640 miles
Differential:
Out: FF
In: Castrol Axle 80W90 GL-5
Transfer Case:
Out: FF
In CQ Full Syn 75W-140 GL-5
375 mL of OEM fluid suctioned out, 375 mL of BMW G3 GL5 70w80 put back in my 2019 JCW Countryman Mini All4. Just under 26000 miles. Old fluid still looked fine, although certainly cloudy compared to new fluid.
2019 Infiniti QX60 Rear Differential and Transfer Case oil change. Canadian Tire 80W90 and Mystik 75W80 used. Milage on QX60 80,600 km, kilometres on these 2 oils was about 34k km & about 2 years.
Wife’s 2018 Durango GT with 79,492 miles.
Front/Rear differentials & AWD Transfer Case fluid changed.
Out: Factory OE fluids
In: Redline 75W85 in the diff’s & Redline D6 in the T-case.
Diff’s oil actually looked like new, T-case looked dark maroon colored & overdue.
2015 Chevrolet Tahoe
Front and rear differential service
Front diff
Out: unknown
In: Supertech 80w90
Rear diff
Out: unknown
In: Supertech Synthetic 75w90
