post your latest differential fluid change
99 cherokee
dana 30 front, corporate 8.25 rear. pumped both diffs and refilled with generic 80w-90
08 Dodge Ram Van B3500
Corporate 9.25" Rear
Unknown mile on fill
Out: Factory Fill?
In: 75/90 Amsoil SVG
2009 Rav4 2.5 4WD. Drained factory 80W-90 in the transfer case and rear differential and replaced it with 75W-90 Mobil 1. 60,000 miles on the clock.
2001.5 Nissan Pathfinder, 2WD
Out: Valvoline High Performance (white bottle) 80W-90, in use for ~12k miles
In: Mobil 1 75W-90
The fluid looked amber and clear draining from the differential, but in the drain pan it looked clear and greyish. I didn't snap a picture. Is there any significance to this color?
In: Mobil 1 75W-90
The grey color is from iron wear. You will almost always see some when draining gear oil.
2009 Cadillac CTS AWD, 20,000 miles. (I'm anal about ff) out, Factory fill, in, Genuine Delco full syn, grape juice. friction modifier for the rear only. looked good. I feel better now...
2006 jeep liberty, 20,000 miles on old gear oil
front: dana 30. 1 1/2 quarts of 80w-90
rear: corporate 8.25. 2 quarts of 75w-90 semi-synthetic
2000 silverado 5.3l z71, Mobil 1 75w90 front diff, rear diff, GM auto-trac 2 for transfer case. Thanks god for drain and fill plug on these, got all done under under 1 hours.
1994 Chevy LLV "Postal Service type truck" with a 7.5" 10-bolt, 2wd.
166,xxx miles
Out: Unknown, but had been changed previous by the city that had owned it (I think? I saw mention in a work order that friction modifier was added at one point. There was a paper gasket on the pumpkin, so that leads me to believe the cover has been off before.
In: 2 qts. (or until it comes out of the fill hole) of Redline 75w90 synthetic Gear Oil with a Victor gasket and Permatex 2b sealant.
2002 Ram 1500 with 3:55 L-Slip 100,450 miles changed (I believe factory fill) with Coastal 80W90.
2004 Ram 1500 QC 4X4 Hemi was changed at approx 30,000 miles at dealer.now has 94,000. due for change soon.
94 Ranger 5spd 4x4. Ford in its wisdom has no diff drains. Stuff in there was looking OK, just low. I topped off diffs with Auto Zone 80 w90, used about 2 qts between them Front diff gasket is weeping.
Most GM and Chrysler rear axles don't have drain plugs either, you are expected to remove the pan gasket every time.
It makes removing the gray slime of death easier.
2010 F-150 FX4
8.8" Front Differential
2nd OC (1st OC was at 13,300)
67,000 miles on oil; 80,300 miles on truck
Out.....Castrol Syntec 75W-90
In......Amsoil Severe Gear 75W-110 (SVT)
UOA to follow soon
1994 Geo Tracker 4x4
Rear Differential
Out: Unknown Gear Oil - at least 9 years and 180,000km (112,000 miles) on oil
In: Castrol Hypoy C 80w90
Old oil looked a bit brown but wasn't as bad as I expected. Not very much in terms of metal shavings on drain plug.
