post your latest differential fluid change
Unimog U500 with 60K miles on the chassis.
4 portal boxes 700ml each + 2 diffs at 2.5L each
Delvac 1 Synthetic Gear Oil 75W90
25000 miles including high heat up to 104F in Australia, some river fording
No water contamination was seen but right rear portal was down to about 300ml with no sign of leakage (sucked into diff thru breather??) or discoloration/burning. Temps in portals stayed below 145F, diffs about 180-190F.
Ratios: diffs 2.182:1 portals 2.714:1
Charlie
2008 Toyota 4 Runner Sport Edition V8 4WD, 42,XXX mi
Changed all 3 diff fluids
Out: Factory fill
In: Mobil 1 75W-90
2005 F-350 (Just about to roll over 100K miles)
Rear:
Out: Assumed factory fill (Supposed to be lifetime but I think 100K is enough)
In: Valvoline SynPower 75W-140
Front:
In: Valvoline DuraBlend 80W-90
Transfer Case:
Out: Unknown (Probably factory fill)
In: Valvoline MaxLife Dex/Merc
Out:
Factory fill
In:
Twin Clutch - Pentosin FFL-2 / SSP paper filter (at 30k miles)
Transfer case - Valvoline 75W-90 SynPower
Rear Differential - Valvoline 75W-90 SynPower
37,000 miles
Able to DIY now as my hoa has eased it regulations to allow fluid changes so...
Switched back to Royal Purple 75w90.
2010 Subaru Tribeca with 30K miles...changed the front and rear differential out factory fill and replaced with Liqui Moly GL-5 full synethic....could not believe how much metal shavings were on the magnetic drain plugs.....will do it again at 60K....
2002 Silverado 1500 4WD 90,xxx miles
IN:
Rear Diff. Mobil1 75W90
Transfer Case Maxlife ATF
Front Diff. Valvoline Durablend 80W90
JP
2004 Chevrolet 1500. 134,000km. No history on rear diff.
Replaced with PetroCan Traxon E 75W90 Synthetic and CLS Limited slip additive.
