post your latest differential fluid change
2022Ram 2500 19,205 miles
Front differential
Out: FF
In: Mobil Delvac 75W-90
Fluid was clear since the truck had less than 5 miles on it in 4X4. Changed the rear differential and transfer case earlier.
2011 BMW 328I XDRIVE E90 43k miles
Replaced original rear differential fluid with Delvac 75w90. The 14 year old fluid came out mostly looking like yellow honey. Some areas were slightly cloudy. This "lifetime fluid " probably didn't need to be changed- yet.
After seeing the condition of the R. Diff fluid, I will likely wait 10k miles to replace the Front Diff, transmission & TC fluids.
2020 GX460 48,714 Miles, drained the OEM fluid out. Filled Front and Rear diffs with Delvac and Transfercase with Redline.
Only observation was the front drain plug had more on the magnet than the rear, otherwise routine maintenance (y)
PS: let's keep the Delvac train going :D
Been using Delvac 1 in my GM 4WD’s for years …
On my Jeep - it’s in the front with ASG in the rear …
2022 Toyota Tundra with 30,095 miles. Mostly metallic gunk on the drain plug, but there was a large sliver of metal stuck to the magnet. Still need to do the front differential and transfer case. Hopefully I can get to that next weekend.
Out: 5.6 quarts Factory Fill 75W-85
In: 5.6 quarts HPL Diff Life 75W-110
Part 2 on the Tundra. 30,585 miles and changed out the front diff and T-case fluid.
Front Differential:
Out: 2.7 pints factory fill 75W-85
In: 2.7 pints Royal Purple 75W-90
Transfer Case:
Out: 2.25 qts factory fill Toyota WS ATF
In: 2.25 qts Toyota WS ATF
2004 Ford Escape, 227,000km. Unsure what came out. The levels appeared fine and nothing was filthy black.
Rear diff got 75w90 group 4 synthetic.
The PTU received the same brand, group 4 80w140.
2011 VW Tiguan, 110.000 miles
Front Differential:
Out: OE fluid (Was surprised how clean it was, 60k on it).
In: Motul Gear 300 75W90
Rear Differential:
Out: OE fluid (super clean, looking new)
Haldex:
Out: OE Fluid (40k, looking good)
In: Ravenol AWD-H
Haldex 4th generation has filter, this is new:
This is old. OMG, this thing gave me such a hard time. I was prying out this filter for probably 2hrs,, more precisely, that yellowish plastic piece. It is such a tight fit that it creates a vacuum that prevents it from getting out. After drilling into it and doing all kinds of monkey business, I finally managed to get some leverage and pry it out.
2014 Toyota rav4 132331kms unknown mileage on fluid, old fluid was dark.
Transfer case Out: unknown
In: motul gear 300 75w-85
Rear diff Out: unknown
1996 Chevy K1500, 298,898 miles, had to replace the right axle seal, which requires removing the rear differential cover to remove the C-clips that hold the axle in.
Out: 2 quarts 26 oz of Valvoline 80W90
In: 2 quarts 20 oz Pennzoil 80W90.
buddy of mine
2019 silverado 1500 5.3L/8l90
115k miles
out: factory fill
in: Valvoline Synthetic 75w90.
factory fluid didn’t look terrible and diff was very clean inside considering he’s lifted on 35’s and drives like he stole it
