Ok guys, I recently purchased a 2000 Nissan Frontier 3.3L with 92,000 miles. I never once thought about looking through the oil fill hole BEFORE purchasing a vehicle, but I have, and if what is below the fill hole is any indication, I have some pretty good sludge going on.
The previous owner didn't drive it much, just short trips, so I am guessing it is like this due to sitting a lot, and the oil being old, even if the miles were ok between changes.
The 3.3 engine isn't a known sludge engine that I know of, so I am at a loss. I will be changing the valve cover gaskets in a few weeks to fix a leak, and will then be able to get a good look, and of course will post a picture on here.
Once taking the valve covers off, is it ok to clean the sludge by hand with rags and a shop vac? I know I would need to be careful not to loosen and leave any large pcs that could clog the passageways, or would you guys advise against touching it, and just letting MMO or ARX run its course? I am thinking about removing it by hand depebnding on how bad it is, along with either MMO or ARX.
I am currently running Pennzoil conventional with a WIX filter. Any brand of oils you would reccomend during the cleaning phase?
Thanks for any and all help guys!
