Originally Posted By: d00df00d
Originally Posted By: Al
If those cores explode (thermally)...the world is History.
You know that's only half the story, right?
If we're going to worry, we need to know the odds that that will happen.
Right, odds are important, but odds are a far more complex thing to put into the consideration. Key first is to just understand what we are dealing with. Al says what is likely there... That is a lot of material.
But as I said a few pages back, whatever was in the bombs that went off over Japan was optimized to do what it did. I can't imagine that a power plant and cooling ponds are optimized for such a rate of energy release, and even in the case of meltdown, it could not propagate instantly. Im no expert, but Im thinking as a chemical engineer, as this is all chemical reactor/plant design in the final analysis.
Now could that be better/worse? That is a lot of speculation. But I can not see how the releases would be more energetic per unit time than a bomb. So then it is a question of if low and slow is better/worse than short and strong. Al/Mola/etc please correct me if my thinking is wrong.
Now, uranium boils at 3800C, Plutonium at a cooler 3200C. Iron melts at 2750C and stone and sand I'd imagine at around 2500C. While the concrete would likely self-destruct at somewhere around 1000C or lower, there would be a LOT of thermal mass, not to mention whatever water would be on top, to absorb heat before the rods could thermally explode or vaporize off into the environment. I'd think that a boric acid bomb or something could be released over the site before such things would happen.
I would think. Which would mean that the odds are VERY low for such a thing. Just my first concept. Thoughts?
