First, hi I'm new here.
I have a Vette with a 416 cubic inch stroked LS3 motor with almost 5K miles on it. It is my daily driver (at least 400 miles per week) and it is my track car. It gets severe open track racing at least 10 times a year.
I was using Mobil 15-50 until it recently got cold. Then on cold starts 40-50* my oil pressure was taking a few second to build and I was getting a low oil pressure warning indicator for a couple of seconds. During warm weather this is not a problem.
So I decided after a week of this to get a thinner oil. I got Mobil1 0-40. The cold startup problem is gone. It is actually very smooth and quiet (no valve train noise) now. I also seem to feel an increase in throttle response...quicker rpm's...less friction??? I do see a decrease in oil pressure when engine is fully warm. Idle is down from 30 to 25-26. Cruising at 2500 rpm is down from 42 to 37. At 3000 rpm it is at 40 psi.
The engine builder recommends synthetic with ZDDP for the life of the car. The Mobil1 15-50 has the right levels. I don't think the 0-40 does. I am OK with adding the ZDDP to the right oil that doesn't have it. I am also OK getting expensive oil like Redline that I believe already has high levels of ZDDP.
So is there an oil that will allow me to have easy cold starts but drive to the track and run at extreme oil temps????????????????????????????????
Thanks in advance for any advise or help!!!!
DH
DH
