Pine sap removal
MTL, CANADA
Hey all, I have pine sap on my paint due to pine trees over my driveway. I have cut them down, but need to remove it from my paint. Tried clay without success, maybe clay wasnt aggresive enough...does anyone have any removal ideas that will be easy on the paint?
Thanks in advance
Thanks in advance
Diesel or kerosene on a rag...works like a charm.
Pine sap is horrible to remove.
Usually I use alcohol or wd-40 depending on the tar.
You will need to wash afterwards.
hand sanitizer is the easy way.
IIRC wd-40 is more for road tar.
Gasoline/fuels should work as well...
Silicone spray lube, WD40, mineral spirits or kerosene and a clean rag will wipe pine sap right away.
I've actually made a small chisel out of plastic for this application. It'll remove the bulk of the tough deposits without scratching the paint. Residual deposits can be removed chemically, such as mineral spirits or alcohol.
goo gone works great.
goof off works even better, but can/will mess up your clearcoat.i speak from personal experience(2 pines along side the driveway)
believe it or not Pine Sol will take it off. I would stay away from hard chemicals when an organic solvent will work.
Get some "gum", or "tree" turpentine, not mineral.
Being extracted from species of pines, it's really good at sap.
