Never really thought about this before, but I am due to change brake fluid in my car...long overdue, and it is to the point I can feel my brakes noticably fading in traffic so I definitely have water in the system. That combined with pads that have some but not much life left (not squealing but I will change them soon), it makes for a pretty low pedal.
My car specs DOT 3, and I know DOT 4 has a higher boiling point but absorbs water more readily. DOT 5 is out of the question for this application.
Of the little bit of information I have, two particularly interest me. One is Ford High Performance DOT 3 fluid because of its extremely high boiling point and ready availability, and another is Ate SL.6. More expensive and DOT 4, but considering how rarely brake fluid gets changed, how important it is, and that it's a lower viscosity brake fluid (it does get cold enough here for odd pedal behaviour in extreme cold) I think it may also offer some advantages. Super Blue would be overkill and it doesn't offer a viscosity advantage like the SL.6 does. I do not have ESP or require a low viscosity fluid, all the specs ask for is DOT 3. Disc front, drum rear, ABS.
How does DOT 5.1 slot into this mix? Mixes with 3 or 4, is it hygroscopic? Is it worth investigating for what most of the time could barely be considered a "severe street" application?
