quote:Maybe so. I did not ask them why. I just figured they knew best. I think that eventhough everything in my engine is new that the old design was not made for a slippery synthetic. Meaning if there is a leak path then it will find it.I don't think it is a myth that synthetic oil can make a engine leak. I have seen it. I will ask them and let you guys know.
Originally posted by GSV: Did you ask them why? Sometimes their reasons are just plain ridiculous. I had a guy at NAPA tell me Synthetics leave the engine parts bone dry at startup where conventional oil clings to the metal.![]()
quote:mazda used to recomend this because the synthetics didn't burn off as well as the dino (kind of a direct injection thing).
Originally posted by uconn1150: For whatever reason (and maybe someone like Molekue may know) but Mazda forbids use of synthetics in their rotaries...
quote:I've heard this a few times but don't get it. The only 2 cycle lubricants that do burn cleanly are synthetic...
Originally posted by tweeker43:quote:mazda used to recomend this because the synthetics didn't burn off as well as the dino (kind of a direct injection thing).
quote:I've run synthetics early on and had no ill effects. Run dino for 100 miles as a "flush" after the rebuild, then fill with synthetic and drive like normal. It's always worked for me... [ October 14, 2003, 11:49 PM: Message edited by: jsharp ]
Originally posted by sbc350gearhead: Most engine builders will tell you not to break the engine in on synthetics. But I have never seen an engine (in good condition), leak with synthetics, that did not leak with a conventional. I have run synthetics on rebuilt (improved) engines for years and have never had a problem after a break-in with a conventional oil.
quote:The rotary engine is different. Oil is in the combustion chambers at all times, therefore burns off slowly. Synthetics are more resistance to burning (in motor oil form, not 2 cycle), so they thicken more and more. Or so I've been told.
Originally posted by jsharp:quote:I've heard this a few times but don't get it. The only 2 cycle lubricants that do burn cleanly are synthetic...
