- Joined
- Jul 16, 2020
- Messages
- 65
BINGO, That's from the oil monkey's that have no clue on how to tighten those filter housings. If you do your own oil changes it shouldn't be an issue.I'm wondering if that's from people overtightening. It's a plastic housing and the cap is sealed with an O-ring. Therefore there's absolutely no reason to try and torque it down any further once it's fully tight. I may go as far to suggest that you loosen the cap by 1/4 turn after it's bottomed out to relieve stress.
I'll disagree with that.BINGO, That's from the oil monkey's that have no clue on how to tighten those filter housings. If you do your own oil changes it shouldn't be an issue.
My argument here would be that because these have an O-ring sealing the cap, you don't need to apply any torque on it at all.I'll disagree with that.
I always torqued ours per the spec (No, I don't trust my feel) and ours leaked.
What year is your vehicle and after how many years did it leak?I'll disagree with that.
Mine is a 2019 bought in August of 2019 and has just under 70K on it. It has been leaking for about 10K miles.What year is your vehicle and after how many years did it leak?
The torque spec is around 24N-m which is next to nothing. I do it just to make sure. Be safe.My argument here would be that because these have an O-ring sealing the cap, you don't need to apply any torque on it at all.
I'm wondering if the leaks are due to the housing cracking or is it from the various smaller sealing o-rings around the housing? If it's the ladder, then there's almost nothing that one can do except upgrade to the metal housing.
2017, leaked last year.What year is your vehicle and after how many years did it leak?
They typically do not crack. They leak where the aluminum oil cooler is attached to the plastic body OR where the plastic body attaches to the aluminum engine block.My argument here would be that because these have an O-ring sealing the cap, you don't need to apply any torque on it at all.
As I noted above, the aluminum version of the filter/cooler is not always the answer either. The design of the sealing surfaces combined with the o-ring material and design is just a bad one no matter what version you choose. Dorman should not have cloned the Mopar version in aluminum, they should have looked at changing the o-rings and surface designs.
They should have machined both sides of the oil cooler and main body for o-ring grooves instead of copying Mopar and leaving the oil cooler surface flat.Interesting that even the aluminum design would have problems. I'm not a fan of Dorman, but in this case they clearly identified a problem with the OE design and came up with a better metal one. Dorman's product page claims that the problem with the OE plastic is that it warps. I'm not entirely sure how they could've redesigned this part any better...the inherent problem is that Dodge/Chrysler made an assembly reliant on way too many little o-rings and thin elastomer gaskets to seal.
Friend of mine with I believe 17’ Ram classic with 3.6 has been using Fram EG cartridge and Providence blend 5w30 for 5-6 for about 119k now. No issues.FWIW I’m currently using Citgo 5w30 FS HM in our 2014 T&C with the 3.6L. I’ve used a variety of Mobil and some Citgo oils with decent results. I always tend to use 5w30 regardless of brand.
Just my $0.02
