peak global and long life... THE SAME???
northeast
here are the specs right off the peak web site it looks like they are exactly the same...
Initial Preparation Date: 7/8/2004
Last Revision Date: None
Effective Date: 8/4/2004
MATERIAL SAFETY DATA SHEET
PRODUCT IDENTITY: PEAK. LONG LIFE ANTIFREEZE & COOLANT
1. CHEMICAL PRODUCT & COMPANY INFORMATION
OLD WORLD INDUSTRIES, INC.
4065 COMMERCIAL AVENUE
NORTHBROOK, ILLINOIS 60062
PHONE: 847-559-2000
EMERGENCY PHONE: 1-800-424-9300 (CHEMTREC)
2. COMPOSITION/INFORMATION ON INGREDIENTS
Material CAS# % by Wt PEL (OSHA) TLV (ACGIH)
Ethylene Glycol 107-21-1 90 - 97 50 ppm 50 ppm
Diethylene Glycol 111-46-6 < 5 None None
Hydrated inorganic acid, proprietary < 5 10 mg/m3 1 mg/m3
organic acid salts
Water 7732-18-5 < 4 None None
PRODUCT IDENTITY: PEAK® GLOBAL LIFETIME ANTIFREEZE & COOLANT
Initial Preparation Date: 10/22/2004
Effective Date: 8/1/2005
PHONE: 847-559-2000
organic acid salts
ARE THESE TWO PRODUCTS THE EXACT SAME, ONLY USE DIFFERENT NAMES,COLORED BOTTLES AND MARKETING????
The specs do not tell us that they are the same since it just lists the crucial ingredient as organic acid salts. It could be 2-EHA, sodium benzoate or some other organic acid salt.
Originally Posted By: Drew99GT
Peak specifically indicates that Global Lifetime does not contain 2-EHA. They don't with Peak Long Life.
I called Peak Tech Support (800 number) and they stated that both Peak Global Lifetime and Peak Longlife are 2-EH free proprietary OAT formulations. They did not imply they were or were not the same.
I asked Peak about Longlife via email once and they stated it did contain 2-EHA.
I had already used it figuring it couldn't be any worse than the likely 13 yr. old Dex-Cool I was draining out
so it didn't really matter anyway.
At the recommendation of follow bitog'ers I followed up my phone call with an email to Peak. Seems their tech support will not put into writing what the 800 number folks stated on the phone
. The following was my email question and their reply.
Q: Do both Peak LONGLIFE and Peak Global antifreeze products exclude 2-EH in its formulation?
A: Thanks for your e-mail. The PEAK LONGLIFE does contain the 2EH, and the PEAK GLOBAL LIFETIME does not.
PEAK Tech Dept.
It would appear the answer has been confirmed "NOT THE SAME"
