Can anyone tell me anything about this oil by looking at the MSDS. I see flashpoint, specific gravity and viscosity @40 and @100. Do these tell anything about the quality of this oil? What's the proprietary stuff? Thanks. (I've deleted the non essential stuff..if anyone wants the full thing, I can email ya the .pdf)
Material Safety Data Sheet
Material Name: Honda Genuine Engine Oil 0W20 GF-4, 12 x 1 Quart Case ID: 2264-042A
____________________________________________________________
Page 1 of 5 Issue Date: 01/10/07 Revision: 1.0000 Print Date: 1/10/2007
Section 1 - Chemical Product and Company Identification
Part Number: 2264-042A
Chemical Name: Mixture
Product Use: Engine Oil
Manufacturer/Supplier Information
Idemitsu Lubricants America
Phone: (812) 284-3300
701 Port Road
Fax: (812) 284-6840
Jeffersonville, IN 47130
Emergency # 1-800-424-9300 (CHEMTREC)
Section 2 - Composition / Information on Ingredients
CAS #
Component
Percent
Proprietary
PR1
5-10
Proprietary
PR2
1-5
Proprietary
PR3
1-5
Additional Information on Hazardous & Non-Hazardous Composition.
Hazard Information: Irritating to Skin & Toxic to Aquatic Organisms.
Section 3 - Hazards Identification
Emergency Overview
Toxic fumes may be released in case of fire. Firefighters should wear full protective clothing and self contained breathing apparatus. If heated above its flashpoint in the presence of air, product can support combustion.
Label Information
WARNING: Never use welding or cutting torch on or near container because product can ignite. Combustible liquid. Launder or discard soiled clothes. Avoid prolonged contact.
Potential Health Effects: Eyes
This product may cause irritation to the eyes.
Potential Health Effects: Skin
Prolonged and/or repeated skin contact with this product may cause irritation/dermatitis.
Potential Health Effects: Ingestion
Will have a laxative effect if swallowed. Low toxicity.
Potential Health Effects: Inhalation
If sprayed or misted may cause chemical pnemonitis. Exposure may cause irritation to eyes, nose, and throat.
Section 4 - First Aid Measures
First Aid: Eyes
Immediately flush eyes with water for at least 15 minutes, while holding eyelids open. Seek medical attention at once.
First Aid: Skin
For skin contact, flush with large amounts of water. If irritation persists, get medical attention. Wash contaminated clothing before reuse.
First Aid: Ingestion
If material is ingested, immediately contact a physician or poison control center. Do not induce vomiting. If vomiting occurs naturally, have victim lean forward to reduce risk of aspiration.
First Aid: Inhalation
Move person to non-contaminated air. If the affected person is not breathing, apply artificial respiration. Seek medical attention.
First Aid: Notes to Physician
Provide general supportive measures and treat symptomatically.
Page 2 of 5 Issue Date: 01/10/07 Revision: 1.0000 Print Date: 1/10/2007
Section 5 - Fire Fighting Measures
Flash Point: 238 C Min
Method Used: COC
Upper Flammable Limit (UFL): N/D
Lower Flammable Limit (LFL): N/D
Auto Ignition: N/D
Flammability Classification: N/D
Rate of Burning: N/D
General Fire Hazards
This product is combustible at high temperatures. Shut off the source of fuel, if possible. Do not cut, weld, solder, drill, grind, or expose containers to heat, flame, sparks, or other sources of ignition.
Hazardous Combustion Products
Irritating and toxic gases or fumes may be released during a fire. Carbon monoxide, carbon dioxide and other hydrocarbon fragments.
Extinguishing Media
Dry chemical, foam, carbon dioxide.
Fire Fighting Equipment/Instructions
Firefighters should wear full-face, self contained breathing apparatus and impervious protective clothing. Firefighters should avoid inhaling any combustion products. Do not direct a solid stream of water or foam into hot, burning pools; this may result in frothing and increase fire intensity.
NFPA Ratings: Health: 1 Fire: 1 Reactivity: 0 Other: B
Hazard Scale: 0 = Minimal 1 = Slight 2 = Moderate 3 = Serious 4 = Severe
Section 6 - Accidental Release Measures
Containment Procedures
Stop the flow of material, if this is without risk. Eliminate all sources of ignition or flammables that may come into contact with a spill of this material. Absorb the spilled material with an inert absorbent (nonflammable) material. Do not allow the spilled product to enter public drainage system or open water courses.
Clean-Up Procedures
Ventilate the contaminated area. Sweep up or gather material and place in appropriate container for disposal. Wash spill area thoroughly. Wear appropriate protective equipment during cleanup. Follow all Local, State, Federal and Provencial regulations for disposal.
Evacuation Procedures
Evacuate the area promptly and keep upwind of the spilled material. Isolate the spill area to prevent people from entering.
Special Procedures
Have emergency equipment readily available.
Section 7 - Handling and Storage
Handling Procedures
When using this material, do not eat, drink or smoke. Avoid prolonged or repeated skin contact with this material. Wash thoroughly after handling.
Storage Procedures
Store in a cool, dry, well-ventilated area. Do not handle or store near an open flame, heat or other sources of ignition. Do not store this material in open or unlabeled containers.
Section 8 - Exposure Controls / Personal Protection
Exposure Guidelines
A: General Product Information
Eye wash fountain and emergency showers are recommended.
B: Component Exposure Limits
Following the OSHA Haz Com 1910.1200 Regulation, the ACGIH, OSHA, and NIOSH have not developed exposure limits for any of this product's components.
Engineering Controls
Use general ventilation and use local exhaust, where possible, in confined or enclosed spaces.
PERSONAL PROTECTIVE EQUIPMENT
Personal Protective Equipment: Eyes/Face
Wear chemical goggles; face shield (if splashing is possible).
Page 3 of 5 Issue Date: 01/10/07 Revision: 1.0000 Print Date: 1/10/2007
Personal Protective Equipment: Skin
Wear impervious gloves for prolonged contact. Normal work clothing (long sleeved shirts and long pants) is recommended. Do not wear rings, watches, or similar apparel that could entrap the material and cause a skin reaction.
Personal Protective Equipment: Respiratory
If mist is generated (heating, spraying) and engineering controls are not sufficient, wear approved organic vapor respirator suitable for oil mist.
Personal Protective Equipment: General
Respirators should be selected by and used under the direction of a trained health and safety professional following requirements found in OSHA's respirator standard (29 CFR 1910.134) and ANSI's standard for respiratory protection (Z88.2-1992). A written respiratory protection program, including provisions for medical certification, training, fit testing, exposure assessments, maintenance, inspection, cleaning, and convenient, sanitary storage must be implemented.
Section 9 - Physical & Chemical Properties
Physical Properties: Additional Information
No additional information available.
Appearance:
Brown Oily Liquid
Odor:
Mild
Physical State:
Liquid
pH:
N/D
Vapor Pressure:
Vapor Density:
Boiling Point:
Melting Point:
N/A
Solubility (H2O):
Insoluble
Specific Gravity:
0.84
Viscosity:
@ 40 C=38.87 @ 100 C=8.301
Section 10 - Chemical Stability & Reactivity Information
Chemical Stability
Stable under normal conditions.
Chemical Stability: Conditions to Avoid
Keep away from heat, sparks, or open flame.
Incompatibility
This product may react with strong oxidizing agents.
Hazardous Decomposition
Hazardous combustion products may include carbon monoxide, carbon dioxide and hydrocarbon fragments.
Hazardous Polymerization
Will not occur.
Section 11 - Toxicological Information
General Toxicity
B: Component Analysis - LD50/LC50
PR1 (Proprietary)
Inhalation LC50 Rat: 2.18 mg/L/4H; Oral LD50 Rat: >5000 mg/kg; Dermal LD50 Rabbit: >2000 mg/kg
PR2 (Proprietary)
Inhalation LC50 Rat: >2.18 mg/L/4H; Oral LD50 Rat: >2000 mg/kg; Dermal LD50 Rabbit: >2000 mg/kg
PR3 (Proprietary)
Carcinogenicity
B: Component Carcinogenicity
Following the OSHA Haz Com 1910.1200 Regulation, the components in this product are not listed by ACGIH, IARC, OSHA, NIOSH, or NTP.
Page 4 of 5 Issue Date: 01/10/07 Revision: 1.0000 Print Date: 1/10/2007
Section 12 - Ecological Information
Ecotoxicity
No information available.
B: Component Analysis - Ecotoxicity - Aquatic Toxicity
PR1 (Proprietary)
96 Hr LC50 Pimephales promelas: >5000 mg/L
PR2 (Proprietary)
PR3 (Proprietary)
96 Hr LC50 Pimephales promelas: >1000 mg/L [semi-static]
Environmental Fate
No information available for the product. Do not allow this material to drain into sewers/water supplies.
Section 13 - Disposal Considerations
US EPA Waste Number & Descriptions
Material, if discarded, is not expected to be a characteristic hazardous waste under RCRA. You must test your waste using methods described in 40 CFR Part 261 to determine if it meets applicable definitions of hazardous wastes.
B: Component Waste Numbers
No EPA Waste Numbers are applicable for this product's components.
Disposal Instructions
Recycling of this product is encouraged. Dispose of waste material according to Local, State, Federal, and Provincial Environmental Regulations.
Section 14 - Transportation Information
US DOT Information
Shipping Name: This product is not regulated as a hazardous material by the United States (DOT) or Canadian (TDG) transportation regulations.
International Transportation Regulations
NOTE: The data in this section (Section 14) is meant as a guide to the overall classification of the product. However, transportation classifications may be subject to change with changes in package size. Consult shipper requirements under I.M.O., I.C.A.O. (I.A.T.A.) and 49 CFR to assure regulatory compliance.
Section 15 - Regulatory Information
US Federal Regulations
Components of this product have been checked against the non-confidential TSCA inventory by CAS Registry Number.
B: Sara Information
Following the OSHA Haz Com 1910.1200 Regulation, None of this product's components are listed under SARA Section 302 (40 CFR 355 Appendix A), SARA Section 313 (40 CFR 372.65), or CERCLA (40 CFR 302.4).
State Regulations
Other state regulations may apply. Check individual state requirements.
B: Component Analysis - State
Following the OSHA Haz Com 1910.1200 Regulation, none of the components in this product are listed on the following state lists :CA, FL, MA, MN, NJ, or PA.
Other Regulations
Sara 311/312: Acute
Page 5 of 5 Issue Date: 01/10/07 Revision: 1.0000 Print Date: 1/10/2007
B: Component Analysis - Inventory
Component
CAS #
TSCA
DSL
EINECS
PR1
Proprietary
Yes
Yes
Yes
PR2
Proprietary
Yes
Yes
Yes
PR3
Proprietary
Yes
Yes
Yes
C: Component Analysis - WHMIS IDL
No components are listed in the WHMIS IDL.
Section 16 - Other Information
701 Port Road
Fax: (812) 284-6840
CAS #
Component
Percent
Proprietary
PR1
5-10
Proprietary
PR2
1-5
Proprietary
PR3
1-5
Emergency Overview
Label Information
First Aid: Eyes
First Aid: Skin
Method Used: COC
Auto Ignition: N/D
Extinguishing Media
Clean-Up Procedures
Special Procedures
Handling Procedures
Storage Procedures
Exposure Guidelines
Appearance:
Brown Oily Liquid
Odor:
Mild
Physical State:
Liquid
pH:
N/D
Vapor Pressure:
Vapor Density:
Boiling Point:
Melting Point:
N/A
Solubility (H2O):
Insoluble
Specific Gravity:
0.84
Viscosity:
Chemical Stability
Incompatibility
Will not occur.
General Toxicity
PR1 (Proprietary)
PR2 (Proprietary)
PR3 (Proprietary)
Carcinogenicity
Ecotoxicity
PR1 (Proprietary)
PR2 (Proprietary)
PR3 (Proprietary)
Environmental Fate
US DOT Information
B: Sara Information
State Regulations
Other Regulations
Sara 311/312: Acute
Component
CAS #
TSCA
DSL
EINECS
PR1
Proprietary
Yes
Yes
Yes
PR2
Proprietary
Yes
Yes
Yes
PR3
Proprietary
Yes
Yes
Yes
