Auto-Trak II - MSDS
Northern California, USA
Here is part of the Auto-Trak MSDS. CHEMISTRI 10/29/02 DISPLAY MATERIAL SAFETY DATA SHEET 16:47:56 SCREEN QA06__ KEY 0000862844,0000000018______________________ FID#: 00343326 VER-DT: 05/07/99 ------------------------------------------------------------------------ SECTION 01: CHEMICAL PRODUCT & COMPANY ID ------------------------------------------------------------------------ PRODUCT PRIMARY NAME: RDL 3239B CHAT SYNONYMS: AUTO-TRAK II > RDL 3239B > 12378508 > 773494 > 88900402 > 9986186 SAFE USE CATEGORY AND DESCRIPTION: 04 -METAL WORKING FLUIDS AND LUBRICANTS LAST UPDATED DATE: 1999-05-07 MANUFACTURER'S ID (MID): 000553637 MANUFACTURER'S NAME: PETRO-CANADA MANUFACTURER'S EMERGENCY PHONE NUMBER/TEXT: CA 403-296-3000 MANUFACTURER'S MAILING ADDRESS: P.O. BOX 2844 CALGARY AB T2P3E3 CA PRODUCT USE: AUTOMATIC TRANSMISSION FLUID DESIGNED PRIMARILY FOR SATURN VEHICLES BUT SUITABLE ALSO FOR OTHER VEHICLE MAKES AND AS A HYDRAULIC AND POWER STEERING FLUID FOR MOBILE EQUIPMENT. ------------------------------------------------------------------------ SECTION 02: COMPOSITION & INGREDIENT INFO ------------------------------------------------------------------------ CAS# FORMULATION W/V CHEMICAL NAME 000100414 T 0.0000/ 0.0000% W BENZENE, ETHYL- 001330207 T 0.0000/ 0.0000% W XYLENE 007446095 T 0.0000/ 0.0000% W SULFUR DIOXIDE 064741884 = 1.8600/ 0.0000% W MINERAL OIL, PETROLEUM DISTILLATES * , SOLVENT-REFINED (severe) HEAVY P * ARAFFINIC 064741975 < 0.0000/ 1.0000% W MINERAL OIL, PETROLEUM DISTILLATES * , SOLVENT-REFINED (severe) LIGHT N * APHTHENIC 064742650 = 1.8600/ 0.0000% W MINERAL OIL, PETROLEUM DISTILLATES * , SOLVENT-DEWAXED HEAVY PARAFFINIC * (severe solvent-refining and/or h * ydrotreatment) 068171506 = 4.3800/ 0.0000% W 2-Propenoic acid, 2-methyl-, dodec * yl ester, polymer with methyl 2-me * thyl-2-propenoate and tetradecyl 2 * -methyl-2-propenoate 072623848 = 12.6200/ 0.0000% W Lubricating oils, petroleum, C15-3 * 0, hydrotreated neutral oil-based, * contg. solvent deasphalted residu * al oil 072623860 = 74.3600/ 0.0000% W Lubricating oils, petroleum, C15-3 * 0, hydrotreated neutral oil-based 074499368 T 0.0000/ 0.0000% W 9,10-Anthracenedione, 1,4-diamino- * , N,N'-mixed 2-ethylhexyland Me an * d pentyl derivs. 989915788 = 5.0200/ 0.0000% W MINERAL OIL 989922365 < 0.0000/ 1.0000% W ACRYLIC COPOLYMER 989981804 < 0.0000/ 1.0000% W HETEROCYCLIC ETHER SECTION 2 - OTHER INFORMATION: THIS PRODUCT CONTAINS THE FOLLOWING ADDITIVE PACKAGES: ACRYLOID 4115, ACRYLOID 1265, HITEC 437, LUBTIZOL 730, AND BLUE DYE #1. THRESHOLD LIMIT VALUE: 8-HOUR TLV-TWA OF 5 MG/M3 RECOMMENDED BY MANUFACTURER BASED ON ACGIH TLV FOR OIL MISTS. CONSULT LOCAL AUTHORITIES FOR ACCEPTABLE EXPOSURE LIMITS. CERCLA (SUPERFUND) REPORTABLE QUANTITY (LBS): NONE AUTO-IGNITION TEMPS: = 202.00C/ 395.00F FLASH POINT TEMPS: = 182.00C/ 359.60F FLASH POINT METHOD: COC FLASH POINT METHOD TEXT: OPEN CUP; CLEVELAND OPEN CUP TESTER, ASTM D9.2.
