SLIP2000 Carbon Killer MSDS
WA, USA
CARBON KILLER
MATERIAL SAFETY DATA SHEET
General Information
Company's Name: SPS Marketing, Inc.
Company's Street: 6819 Redwood Rd
Company's City: Cotati
Company's State: CA
Company's Country: US
Company's Zip Code: 94931
Company's Emerg Ph #: CHEMTREC 800-424-9300
Company's Info Ph #: 707-585-8329
Date MSDS Prepared: 09Mar06
Preparer’s Name: Roger Curry
Preparer’s Company: Nevada Ecotec
Preparer’s City: Reno
Preparer’s State: NV
HMIS Information: Health: 1 Flammability: 1 Reactive: 1 Protection: B
Hazard Characteristic Code: F1
Unit Of Issue: Various
Net Unit Weight: Various
Ingredients/Identity Information
Proprietary: NO
Ingredient: CYCLOHEXENE, 1-METHYL-4-(1-METHYLTHENYL)-, (D-LIMONENE)
Ingredient Sequence Number: 01
Percent: 15-20
NIOSH (RTECS) Number: GW6360000
CAS Number: 5989-27-5
OSHA PEL: NOT ESTABLISHED
ACGIH TLV: NOT ESTABLISHED
Other Recommended Limit: None Specified
Proprietary: NO
Ingredient: WATER
Ingredient Sequence Number: 02
Percent: 35-40
NIOSH (RTECS) Number: ZC0110000
CAS Number: 7732-18-5
Proprietary: NO
Ingredient: MONOETHANOLAMINE
Ingredient Sequence Number: 03
Percent: 5-10
NIOSH (RTECS) Number: KJ5775000
CAS Number: 141-43-5
2
Physical/Chemical Characteristics
Appearance And Odor: GREEN LIQUID; CITRUS ODOR
Boiling Point: 212ºF, 100ºC
Melting Point: UNKNOWN
Vapor Pressure (MM Hg/70 F): UNKNOWN
Vapor Density (Air=1): UNKNOWN
Specific Gravity: 0.95±.02
Decomposition Temperature: UNKNOWN
Evaporation Rate And Ref: (Water=1) 1.0±.2
Solubility In Water: UNSTABLE EMULSION
Percent Volatiles By Volume: 85%±3 @100ºC
Viscosity: UNKNOWN
pH: 10.4-11.0
Corrosion Rate (IPY): UNKNOWN
Fire and Explosion Hazard Data
Flash Point: Above 180ºF
Flash Point Method: TCC
Lower Explosive Limit: UNKNOWN
Upper Explosive Limit: UNKNOWN
Extinguishing Media: FOAM, DRY CHEMICAL, CARBON DIOXIDE, WATER FOG OR
SPRAY.
Special Fire Fighting Proc: AS FOR ANY COMBUSTIBLE HYDROCARBON. USE AIR
SUPPLIED BREATHING EQUIPMENT. AVOID BREATHING VAPOR OR FUMES. COOL EXPOSED
CONTAINERS WITH WATER SPRAY.
Unusual Fire And Expl Hazrds: COMBUSTIBLE LIQUID. DO NOT STORE OR MIX WITH
STRONG OXIDANTS. EMPTY CONTAINERS MAY RETAIN PRODUCT RESIDUE. DO NOT CUT OR
WELD ON OR NEAR CONTAINERS.
Reactivity Data
Stability: YES
Cond To Avoid (Stability): OPEN FLAMES OR WELDING ARCS.
Materials To Avoid: STRONG ACIDS AND STRONG OXIDIZING AGENTS.
Hazardous Decomp Products: INCOMPLETE COMBUSTION PRODUCES VAPOR, SOOT,
CARBON DIOXIDE AND CARBON MONOXIDE
Hazardous Poly Occur: NO
Conditions To Avoid (Poly): NOT APPLICABLE
Health Hazard Data
LD50-LC50 Mixture: ORAL LD50 (RAT) IS UNKNOWN
Route Of Entry - Inhalation: YES
Route Of Entry - Skin: YES
Route Of Entry - Ingestion: YES
Health Haz Acute And Chronic: ACUTE: EYE IRRITANT. PROLONGED SKIN CONTACT
CAN CAUSE IRRITATION OR DERMATITIS. GLYCOL ETHER COMPONENT CAN BE ABSORBED
THROUGH SKIN; HARMFUL AMOUNTS NOT EXPECTED IN NORMAL USE. EXCESS INHALATION
MAY CAUSE NOSE AND RESPIRATORY IRRITATION; HEADACHE, NAUSEA, DIZZINESS.
INGESTION: IRRITATION, NAUSEA, VOMITING, DIZZINESS.
Carcinogenicity - NTP: NO
Carcinogenicity - IARC: NO
Carcinogenicity - OSHA: NO
Explanation Carcinogenicity: NONE OF THE CHEMICALS IN THIS PRODUCT IS
LISTED BY IARC, NTP OR OSHA AS A CARCINOGEN.
Signs/Symptoms Of Overexp: LONG TERM OVEREXPOSURE TO SOME GLYCOL ETHERS BY
SKIN ABSORPTION OR INHALATION MAY CAUSE KIDNEY, LIVER, OR BLOOD EFFECTS.
Med Cond Aggravated By Exp: RESPIRATORY DISORDERS MAY BE AGGRAVATED BY
INHALATION. SKIN CONTACT MAY AGGRAVATE EXISTING DERMATITIS.
Emergency/First Aid Proc: EYES: FLUSH WITH RUNNING WATER FOR 15 MINUTES
WHILE HOLDING EYELID. GET MEDICAL ATTENTION IMMEDIATELY. SKIN: WASH WITH
REMOVE TO FRESH AIR. GIVE MOUTH-TO-MOUTH RESUSCITATION IF NOT BREATHING.
GET MEDICAL ATTENTION. INGESTION: DO NOT INDUCE VOMITING. IF CONSCIOUS GIVE
DRINK OF WATER TO DILUTE. GET MEDICAL ATTENTION IMMEDIATELY.
Precautions for Safe Handling and Use
Steps If Material Released/Spill: VENTILATE AREA AND USE APPROPRIATE
PROTECTIVE EQUIPMENT. SMALL SPILLS: MOP UP ALL POSSIBLE. FLUSH RESIDUE WITH
WATER. LARGE SPILLS: DIKE TO CONTAIN LIQUID, RECLAIM ALL POSSIBLE. ABSORB
REMAINDER ON INERT MATERIAL AND PLACE IN CLOSED CONTAINERS.
Neutralizing Agent: NONE SPECIFIED BY MANUFACTURER.
Waste Disposal Method: DISPOSE OF IN ACCORDANCE WITH LOCAL, STATE AND
FEDERAL REGULATIONS. IF DISPOSED OF AS RECEIVED, PRODUCT IS AN IGNITABLE
HAZARDOUS WASTE DUE TO FLASH POINT.
Precautions-Handling/Storing: USE WITH ADEQUATE VENTILATION. AVOID
BREATHING VAPORS. DO NOT STORE OR HANDLE NEAR HEAT, SPARKS, FLAME OR STRONG
OXIDANTS. KEEP CONTAINER CLOSED.
Other Precautions: DO NOT REUSE EMPTY CONTAINER. STORE ONLY IN ORIGINAL
CONTAINER. AVOID PROLONGED OR REPEATED SKIN CONTACT. WASH CONTAMINATED
CLOTHING BEFORE REUSE.
Control Measures
Respiratory Protection: NOT NORMALLY NEEDED. USE NIOSH/MSHA APPROVED
RESPIRATOR IN ENCLOSED AREA OR IF SPRAY OR VAPOR IN AIR CAUSES IRRITATION.
Ventilation: AS NEEDED IF VAPOR OR SPRAY IN AIR. USE NONSPARKING
EQUIPMENT.
Protective Gloves: SOLVENT RESISTANT
Eye Protection: SAFETY GLASSES OR GOGGLES
Other Protective Equipment: AS REQUIRED TO PREVENT PROLONGED OR REPEATED
SKIN CONTACT.
Work Hygienic Practices: WASH SKIN CONTACT AREAS IMMEDIATELY. WEAR SOLVENT
RESISTANT GLOVES FOR OTHER THAN INCIDENTAL HAND CONTACT WHILE USING.
Suppl. Safety & Health Data: HAZARDOUS CARBON MONOXIDE GAS MAY BE FORMED UPON
CONTACT WITH HOT SURFACES
Transportation Data
DOT Proper Shipping Name: NOT REGULATED BY THIS MODE OF TRANSPORTATION
IMO PSN Code: ZZZ
IMO Proper Shipping Name: NOT REGULATED FOR THIS MODE OF TRANSPORTATION
4
Disposal Data
See Above: Control Measures and Safe Handling Precautions
Label Data
Label Required: YES
Label Status: G
Common Name: CARBON REMOVER
Signal Word: CAUTION!
Acute Health Hazard-Slight: X
Contact Hazard-Slight: X
Fire Hazard-Slight: X
Reactivity Hazard-None: X
Special Hazard Precautions: ACUTE: EYE IRRITANT. PROLONGED SKIN CONTACT
INGESTION: IRRITATION, NAUSEA, VOMITING, DIZZINESS. USE WITH ADEQUATE
VENTILATION. AVOID BREATHING VAPORS. DO NOT STORE OR HANDLE NEAR HEAT,
SPARKS, FLAME OR STRONG OXIDANTS. KEEP CONTAINER CLOSED.
Protect Eye: Y
Protect Skin: Y
Protect Respiratory: Y
Label Name: CARBON KILLER
Label Street: 6819 Redwood Dr
Label City: Cotati
Label State: CA
Label Zip Code: 94931
Label Country: US
Label Emergency Number: CHEMTREC 800-424-9300
Disclaimer
To our actual knowledge, the information contained herein is accurate as of
the date of this document. However, neither Nevada Ectec or its affiliates or
employees makes any warranty, expressed or implied, or accepts any liability
in connection with this information or its use. This information is for use
by technically skilled persons at their own discretion and risk and does not
relate to the use of this material in combination with any other substance or
process. This is not a license under any patent or proprietary right. The
user alone must finally determine suitability of any information or material
for any contemplated use, the manner of use and whether any patents or
intellectual property rights are infringed.
I wish they wouldn't have added the citrus smell. It stinks up my whole gun room! Bill T.
