Quick recap of bad luck. Wife's 2012 Civic LX has 125k on it. Figured I would replace the PCV valve. Took the old off, threaded the new one on by hand, set my torque wrench to spec (32 lbf*ft), gave it a twist, and the S.O.B. PCV valve snapped mid threads.
Not having any way to get the other threads out of the block I called a trusted mechanic two miles down the road who told me to bring it to him. Drove it there with no PCV valev installed, he got the threads out, drove it back no PCV valve installed, threaded the old PCV valve (which still works) back down tight by hand, slapped a wrench on it and tried to give it an easy twist and it didn't move so I called it good enough.
In the meantime, since I drove it to the mechanic and back the emissions system obviously didn't like that. I cleared the temporary codes with my OBDII scanner, drove it again and all of the warning lights remained off (check engine, power steering, VAS system) but the permanent code remains in the computer:
P1129 Honda Permanent
MAP Sensor Signal Higher Than Expected
Will the computer eventually erase this code after driving enough time that it sees the issue doesn't exist anymore, or will I need to take it to the mechanic again to get them to clear it? Maryland emissions only look for these types of codes for pass/fail, so whenever that is due it could be a pain in the butt.
