Wife just took Expedition to mechanic for AC service.
98 Expedition, 5.4
After the service, she noticed the vehicle surging and "running rough"
Later the CEL came on. I believe PO750 code.
I called mechanic, he said all the AC work he did was up top and easily accessible, so likely a coincidence.
I cleared light and test drove and the problem was noticeable and CEL came back on.
I disconnected connection at shift mechanism at transmission and re-plugged. It looked clean and in good shape.
I moved around wires and pressed on connectors in the accumulator area on the firewall, cleared CEL and test drove.
Problem improved, but around 45 mph, the shift became erratic again and shortly after problems on lower shift range as well. No CEL yet, but definitely something is not right.
Where is the wiring harness connection for the shift solenoid?
It seems like the problem is in multiple ranges, so what would be the likelihood that the solenoid pack could be bad?
Any other diagnostic tips?
98 Expedition, 5.4
