He's basically right. Although, you can actually go about an added +0.5 higher HTHS from the oil recommended in your owner's manual and it could help you when towing, hauling, racing, and/or in hot weather. Going thicker than that is kinda useless. Example: there was a thread the other day, a guy with a '15 BMW M5 hot-rod who knew BMW said LL-01FE 0w30 HTHS 3.1 oil was fine for his engine. I tried to convince him that he didn't need anything higher than HTHS 3.6 for some "added margin" on top of BMW's own specs when driving it hard.
Of course, high fuel-diluter engines can probably go up to +1.0 HTHS higher with no ill effects. So there are exceptions, and sometimes slightly thicker is better for wear.
As pointed out already, the BG oil supplement sign behind him means he likes sponsor money more than good advice, since owner's manuals often say "don't use addtives".
